95 Volvo with m11 motor, truck won't start without ether.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brookshire36, Feb 11, 2021.
  1. Brookshire36
    Brookshire36 Bobtail Member
    18
    Apr 28, 2020
    I acquired another truck with another problem, the truck won't start without using alot or ether and after you get it running even for hours upon hours if you accidentally drop the clutch or #### it off it wint crank back up by itself without using more ether, checked fuses and switch any help be appreciated thanks in advance
  3. Fieldrat
    Fieldrat Bobtail Member
    43
    67
    Jan 31, 2021
    You need to check for air in fuel and restriction first. Get a clear line between your pump inlet and tank and look for milky appearance or a lot of bubbles. Can also put a hose on the return side and run into a bucket of fuel and look for excessive bubbles in the bucket. Restriction gage at the pump inlet, 0 to -30 in is best to use. If a lot of restriction is found keep plumbing the gauge back toward the tank till you find it.
    If no gauges run out of a bucket and see if it starts.
    Also need to check fuel pressure at the fuel pump. There should be a compucheck fitting at the inlet of the gear pump. You should have 25 psi in under 6 seconds. If the gauge moves very slowly or takes longer than 6 seconds to build pressure the pressure regulator is stuck.
