'96 cat engine flash codes
Discussion in 'Trucks [ Eighteen Wheelers ]' started by slimwitkins, Dec 25, 2015.
  1. slimwitkins
    slimwitkins Bobtail Member
    Flash codes 2, 52, 61, 3 or 31. What do they mean? Think the 2 means start of flash codes. Can't find 52 anywhere. Don't know what 3 means.
  3. SL3406
    SL3406 Medium Load Member
    550
    1,491
    Jan 10, 2011
    Oklahoma
    31 loss of vehicle speed signal, 61 high coolant temp, There isn't a 52. 42 is cam sensor calibration, 62 is low coolant. There are no single digit codes like 2 or 3 either.
  4. josh polk
    josh polk Light Load Member
    142
    64
    Dec 20, 2015
    Bowie TX
    Just FYI if u have the cat engin Manuel it has all the codes in it 99% trucks have one in it
  5. slimwitkins
    Thank y'all. I figured out. The codes were actually 25, 26, and 13. The first place I read the way to run codes it said a 2 would flash before a codes start. The headhad recently been replaced. Somehow the boost pressure sensor had gotten plugged into the fuel temp sensor, so neither were hooked to the wiring to the ecm. I do need to know what sensor is between the middle and back valve covers on the driver's side.
  6. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    This might help you...
    http://ww2.justanswer.com/uploads/yellowman99/2010-05-10_232858_70_OEM.pdf
  7. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    The sensor your referring to is i believe to be your intake air temp sensor.
    Boost sensor is closer to front valve cover.
