96 Pete & 3406b questions.
Discussion in 'Peterbilt Forum' started by sbatson, Feb 14, 2012.
  1. sbatson
    sbatson Light Load Member
    232
    10
    Feb 14, 2008
    Ft Worth, Texas
    Its a 96 pete that came with no jakes or cruise where would be a good place to start looking for these parts? Also the motor going into the truck it has a mechanical fan not an air operated fan is this better? Was told so. The motor is rated at 425hp was also told I could turn it up by just a few turns of a screw. The truck is a 96 379 with 63 flattop 3406b, 9 speed direct, 38,000 rears, we are putting this truck to a low boy so any info or does and donts would be great. Thanks
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    I would checkout some of the slavage yards for the Jake setup im in so cal I use acne truck parts in stockton there are several diffrent places around the coutry if you go to http://www.heavytruckparts.net/index.phpthey have anything you could need
  4. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    I would go with the air fan hands down less fuel less noise not sure about the cruise I think there's a company that makes a kit but I can't think of the name
  5. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Well first off you will have to go with RoadKing cruise control if you want it.
    As for Jakes, depending on which motor number you have the only way to go is with the 349A jakes. All others are worthless. Now if someone gives you another set like the 346's go ahead and put them on but I wouldn't buy them, IMO.
    Go with an air over electric fan.
  6. sbatson
    232
    10
    Feb 14, 2008
    Ft Worth, Texas
    I was thinking air to plus i can control it with the switch inside. I will check out the site to for jakes. I think its going to need a fan clutch because I noticed that that the fan would spin with ease with no air to it, shouldnt they get stiff when no air is supplied?
  7. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    No you should have the old style it takes air to engage the fan so no air means it should be free new style take air to release and use spring pressure to lock it in so no air means fans locked I have to to bad your not near so cal I have a complete set of jakes from a 3406b
  8. sbatson
    232
    10
    Feb 14, 2008
    Ft Worth, Texas
    Well then thats good news about the fan clutch Ill switch it over. The jakes we are going to need the whole set up, jakes, bolts, wires, switch etc... right since it didnt come with any? Ill be back at work Friday if your interested and we come up with a price Ill talk to the bossman and maybe get these from you.
  9. sbatson
    232
    10
    Feb 14, 2008
    Ft Worth, Texas
    Well I will get the fans switched back. If bossman is good with it and you maybe we can come up with a price and pick those up from you. We will need the jakes, bolts, wiring, switch etc... right since the truck didnt come with any?
  10. AJ n AK
    AJ n AK Bobtail Member
    Kenai,AK
    349A...........349A......349A.......'SUPERJAKES'..........ONLY ONE TO BUY!!!!! TRUST ME ,GOT SOME,AS GOOD AS MY RETARDER. 346 jakes are what I call "JOKEBRAKES".Mine are in corner of shop,scrape metal,want them?:biggrin_25513:
