96 w900 jakes and cruise
Discussion in 'Kenworth Forum' started by Asanchez, Mar 24, 2021.
  1. Asanchez
    Asanchez Bobtail Member
    28
    17
    May 17, 2020
    does anybody know how to wire the 3 prong clutch switch on a Kenworth.? Jakes and cruise Switch’s have no power. Clutch switch is new. Has 2 sets of wires one says clutch switch common and the other wire says clutch switch norm open but clutch switch has another prong that says open
    1996 Kenworth w900
    12.7 Detroit
  3. AModelCat
    159,387
    I believe you only use 2 terminals. Its more or less a generic microswitch with a Common pin and the other 2 are Normally Open and Normally Closed.
    Not 100% sure but I'm thinking you'd want to use the Common and the Normally Open pin. That way the clutch pedal would keep the switch closed and then open (break) the circuit when you press in the clutch.
    Bean Jr. Thanks this.
  4. Asanchez
    28
    17
    May 17, 2020
    Ok thank you I’ll try it. Are these wires supposed to be grounds or hot wires also? Never had to fight this problem so I’m all confused
  5. AModelCat
    159,387
    That, unfortunately, I can't answer. I haven't wrenched on trucks in several years so I don't remember.
  6. Asanchez
    28
    17
    May 17, 2020
    I appreciate the help
  7. Hulld
    Hulld Road Train Member
    2,883
    6,567
    Oct 19, 2015
    Upstate NY
    I don’t really believe they are hots or grounds per say.
    It’s mainly just a switch in series that interrupts the completed circuit to shut the Jake off... if that makes any sense to you?
    With out a schematic I believe the way @AModelCat said to wire the switch makes perfect sense and I would start with that.
  8. Asanchez
    28
    17
    May 17, 2020
    @Hulld that makes sense what you are say. I’ll try to wire it again and see what happens been fighting this problem for a while now
    Hulld Thanks this.
  9. Hulld
    2,883
    6,567
    Oct 19, 2015
    Upstate NY
    Give it a try and check back.
    Many will try to help you here.
  10. Asanchez
    28
    17
    May 17, 2020
    @AModelCat and @Hulld finally found the time to mess with the wiring on the clutch switch in between work and rebuilding a cat motor. Plugged common up and norm open started the truck still no power to cruise or jakes but then the truck would not shut off. So then I plugged norm open to just open and truck shut off I’m at a loss here
  11. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    I think you probably ought to check the speed sensors on rear of transmission
