98 379 suspension height
Discussion in 'Peterbilt Forum' started by glenn14, Mar 30, 2014.
  1. glenn14
    glenn14 Bobtail Member
    19
    Have 98 379 w/air leaf suspension. Measuring from bottom of frame to bottom of airbag housin, what should it be?
  3. Davidlee
    Davidlee Medium Load Member
    419
    156
    Aug 31, 2012
    On a standard air leaf the distance from the bottom of frame to bottom of air spring support will not be the same for all and will affect driveline angle.
    glenn14 Thanks this.
  4. glenn14
    19
    Thnx. I've had 3 different Pete Mech tell me different #'s. I've been tryin to get it right instead of puttin in shop. 1 told me today that frame shouldnt be higher than tires. I tried it & to do so theres hardly any air in bags
  5. Davidlee
    419
    156
    Aug 31, 2012
    Try 30-32 inches bottom of frame to ground. I don't know what it should be but I worked on one and that's where it was.
  6. glenn14
    19
    10-4. I'll stop & try it. Thnx.
  7. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    I try to set it so that, viewed from the side, the interaxle driveshaft lines up straight with the rear axle's pinion shaft. The interaxle driveshaft is already at an angle between the front and rear axles when viewed from above, too much angle when viewed from the side will exceed the u-joint's design limitations and induce vibration.
  8. glenn14
    19
    Point well taken. Thnx
  9. Boardhauler
    Boardhauler Road Train Member
    1,715
    3,501
    Dec 21, 2008
    Ballin' in it for Shakey
  10. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Use the chart that Boardhauler posted. Measuring from the frame to the ground to compare to a different truck is not a good way to do it unless you're sure it's the same suspension and tire size. Top of the frame compared to the tire does not matter, that changes with tire size & suspension type.
  11. DSTdriver
    DSTdriver Bobtail Member
    12
    Oct 28, 2013
    Pretty sure bottom of frame to bottom air bag mount should average between the front and back At 11 1/2 " always been good for my trucks
