98 397 strange humming sound coming from the engine copartment
Discussion in 'Peterbilt Forum' started by tmslogistics, Jan 15, 2016.
  1. tmslogistics
    tmslogistics Light Load Member
    138
    15
    Mar 10, 2015
    I can hear this at idle. it's a higher frequency hum coming from somewhere under the hood. That's about all I can narrow it down to. It's not belts....not a squeal, but a hum.
    Could it be power steering pump?
    Fan clutch?
    Any ideas will be greatly appreciated.
    Motor is a 3406e 6TS
    Thanks guys,
    Toby
  3. tmslogistics
    138
    15
    Mar 10, 2015
    It's been doing this for a very long time. Can't remember when it started. May have been doing this when I bought the truck 4 years ago.
    Anyway.....I hate to run my truck when I sleep. So, most of the time it's off, unless it's warm out and I need to run the A/C.....or, warm up the truck for heat.
    It's really getting on my nerves when trying to sleep. I'm sure it bothers they folks that park next to me too.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,483
    6,526
    Aug 26, 2014
    Does it have an add on centrifuse oil filter bolted on the frame rail?
  5. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    CK alt. bearing can get worn and make sound, you can take off belts and crank up eng. for just long enough to see if sound stops?
  6. alanbigwheels
    alanbigwheels Bobtail Member
    16
    Aug 16, 2013
    Saskatoon Saskatchewan
    Cab or motor mounts possibly?
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Check you fan hub immediately. Remove the belts and check the bearings for play and spin it check for any roughness in the bearings. While the belts are off, check all the other accessories and pulleys. If the fan hum comes apart, it can cause some expensive damage. It may not be your noise, but eliminate that possibility by checking it.
