98 kenworth fan clutch sticking
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TommyZ, Jun 15, 2018.
  1. TommyZ
    TommyZ Light Load Member
    102
    39
    Miami,FL
    Hope everyone is good. I am having an issue that I cant figure out. Been doing some research and nothing. My truck is a 98 kenworth T600 3406e. I have a Horton fan clutch (less then 6months old) it’s the older style one that is normally released and engages with air. It’s working when on but when I turn the fan off it doesn’t disengage completely. It’s partially engaged even with no air. I tapped the top of it with a hammer and then it disengaged. Any ideas. I thought to spray some wd40 into the air line? I got my air hose and blew me air thru it but continues to do the same thing. Any ideas. Don’t really want to pull it apart until I get home next week.
  3. skallagrime
    skallagrime Road Train Member
    3,597
    9,148
    Apr 10, 2012
    Indiana
    Pretty sure it is either too loose or too tight on the hub bearing itself, if I remember correctly, adding wd 40 to the air line won't help since that won't lubricate the part that is sticky, it's worth a shot if you can't really pull it apart for a week though.
  4. TommyZ
    102
    39
    Miami,FL
    Yeah that’s what I thought about spraying some wd in the air line. Thanks for the response. I am on the road until next Thursday so I don’t really want to pull it apart until I am home. It is working just. Worst would be that it wouldn’t engage I guess.
