98 pete 379 trouble with air leveling valve
Discussion in 'Peterbilt Forum' started by cindymz, Jan 20, 2014.
  1. cindymz
    cindymz Bobtail Member
    13
    I have a 98 pete 379 3406e cat. I had a three axle alignment done. I was in the truck with it not running, and the next thing I hear is like a boom, then air starts leaking. The leveling rod came off the rubber gromet on the bottom, air was coming out of the line. When you move the rod up and down it is very loose. When they do an alignment do they take that off for some reason? And there is no air in the air bags. Does that mean that valve is no good?
    Thanks appreciate the help.
  3. TwinStickPeterbilt
    TwinStickPeterbilt Heavy Load Member
    707
    910
    Mar 16, 2013
    You'll need a new valve. It's used to adjust air bag pressure.
  4. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    you might need to buy new arm,1st ck for clamp on rubber rod being tight?
  5. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    Probably just timing. They shouldn't have had to mess with the leveling valve.
    Sounds like something got into the valve causing it to stick. Might be able to put it back together with no problems.
    And sometimes they just go out.
    I've yet to find a leveling valve to last for a long time without leaking. I've actually had new ones leak 1-2 months down the road.
  6. cindymz
    13
    Thanks everyone for the help.
  7. Flightline
    2,345
    1,165
    Oct 1, 2011
    Almost There
    Your Welcome. That's what the forum is for.
    Also there is a Thanks button on each reply to give thanks numbers to those who deserve it.
