98 w900 cab airbags not airing up
Discussion in 'Kenworth Forum' started by irishluck09, Jul 31, 2023.
  1. irishluck09
    irishluck09 Light Load Member
    269
    133
    Nov 24, 2019
    Not sure what to look at first. Leveling valve?
    Just notice that the cab bags aren't airing up. Rest of the truck has air no problem
  3. Oxbow
    Oxbow Road Train Member
    12,694
    131,021
    Nov 24, 2015
    There should be a pressure regulator between the air supply and the leveling valve. Often these get gunked up over the years and do not open to allow air to pass. Break the air line leaving the regulator to the leveling valve and see if you have flow there. If not, need to replace the regulator. If so, it must be in the leveling valve.
  4. irishluck09
    269
    133
    Nov 24, 2019
    Got it. Is that regulator in the same area as the leveling valve or in a different location
    Oxbow Thanks this.
  5. Oxbow
    12,694
    131,021
    Nov 24, 2015
    I'm not sure on yours, but on ours they are mounted right off of one of the tanks. If you chase the supply line to the leveling valve back you should find it.
