99 century 12.7 detroit. Anyone knows what is code 62?
Discussion in 'Freightliner Forum' started by trucker359, Apr 16, 2014.
  1. trucker359
    trucker359 Bobtail Member
    11
    I been having problems with the engine, first lack of power and some times when start shifting gears engine feels like stalling and running out of fuel and dies. but start it again and goes fine.
  3. TruckerLife1
    TruckerLife1 Bobtail Member
    11
    Nov 20, 2013
    [h=4]Fault Codes for Detroit Diesel Series 60 Engines[/h]Have you ever wondered what those engine codes mean when you have a check-engine light on in your truck?
    Well, wonder no more because the following codes are supplied as a trouble-shooting guide for mechanics. These codes are not for the faint-of-heart, and you should always have your truck serviced by a qualified professional
    • These codes are for your reference only. Detroit Diesel Series 60 Engines only
    • Please note: Codes 43, 44, and 45 are critical codes and if they are shown, the Stop Engine Light will come on which causes the engine protections to engage and your engine may shut down.
    • All other codes will cause the Check Engine Light to come on which will not engage the engine protections and will allow the engine to continue running.
    • If any of these codes are shown, please contact the nearest Detroit Diesel service center.
    [TABLE="class: presentation"]
    [TR]
    [TD][/TD]
    [TD]62-Auxiliary Output Short ot Battery or Open Circuit or Mech Fault
    https://www.tripsheetcentral.com/20...des-for-detroit-diesel-series-60-fault-codes/[/TD]
    [/TR]
    [/TABLE]
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Sounds like you have a short in the wiring by the code. But you need the numbers that follow the code 62 to narrow it down. There should be a SID and FMI number after the 62.
    About the only 2 things that will shut the engine down is a lack of fuel or loss of power to the ECM. So maybe the short is directly related to the ECM. Maybe the ECM hot wire rubbed the insulation off and is barely touching ground or something similar. You can look at the little wire coming off the battery hot and see if you see any insulation damage. It would have to be before the inline fuse or it would of blown the fuse.
    Other than that if you can't get the full code the laptop will have to be hooked up to retrieve it.
  5. DustyRoad
    DustyRoad Road Train Member
    1,540
    17,104
    Feb 23, 2011
    Gulf of Mexico
    Code 62 code 62, Doctor Detroit....we have a code 62. If your truck is running but the engine check lite stays on, a fault remains in the buffer log...and can only be cleared by Doctor Detroit and his Techs at the shop. I had a fault/engine check lite on my Pete for a couple of months due to a injector that malfuctioned, the CAT was fine, even though the light was on.
  6. nikmirbre
    nikmirbre Road Train Member
    5,376
    9,583
    Jul 27, 2011
    High Point NC
    if im not mistaken, only flash codes on a 99 no SID or fmi numbers.....
  7. CondoCruiser
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    I believe on that truck you push and hold down a certain button for like 3 seconds for further diagnostics or it requires the laptop like dusty said the full code is in the buffer log. I'm just going by the code chart for a Series 60 DDEC IV which that truck has. There are several possibilities and the SID and FMI would help narrow it down. It's a yellow code so it points to a specific item shorting out.
    http://diesel.btc.ctc.edu/Engines/Detroit Diesel/EGR s60techguide.pdf
  8. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    That is correct. Hold the shutdown override button. The shutdown light (red) will flash active codes, the warning (amber) will flash inactive. Code 25 is "No codes". Active codes will go inactive once fixed, but the only way to clear inactive faults is with a laptop.
  9. biofumes
    biofumes Light Load Member
    202
    96
    Feb 13, 2009
    California
    What type of software are y'all running on your labtop? Also, where does one go to purchase it?
  10. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    I have DDDL, you get it from Detroit. Expensive and not worth it unless you have a fleet or repair shop. The best option I found for owner ops or small fleets is PF Diagnose. http://www.pocketfleetdiagnosticsolutions.com/ It can't do everything OEM software can do, but it can do a lot for the price.
    biofumes Thanks this.
