99 Classic Xl Brake Problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Puller810, Dec 1, 2011.
  1. Puller810
    Puller810 Bobtail Member
    32
    15
    Jan 17, 2011
    I have a 99 Classic Xl. Brakes started sticking on when pressing the foot pedal, it wouldn't release the air pressure. In the morning the pedal would be really hard to depress then it would break free. I changed the foot valve thinking it was bad and just tried it this morning. Same thing after messing with it you can get the brakes to release and the pedal will come back. Any ideas would be appreciated!
  3. heyns57
    heyns57 Road Train Member
    2,209
    1,011
    Dec 30, 2006
    near Kalamazoo Speedway
    Are your air dryer and spitter valve working? Temps below 30 have arrived in Michigan.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    check accelerating valve.
  5. Puller810
    32
    15
    Jan 17, 2011
    Air dryer is working along with the splitter.
    Pablo, where is the valve you are talking about located?
    Thanks for the help!
  6. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Brake pedal pivot or actuator piston froze or packed with dirt and grime.
    heyns57 Thanks this.
  7. Puller810
    32
    15
    Jan 17, 2011
    I was hoping I wouldn't have to tear the dash a part but I think it might be that.
  8. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    You have to remove the foot pedal. either pull the pin or remove the complete assembly, sand and clean all the parts. I lube with luberplate, and reassemble.
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    This valve in on frame x-member. You got the truck with Early Bosch ABS (and Knorr/Bendix brake system). So no accelerating abs valves were used and they used to put one accelerating valve on frame x-member in fifth wheel area.
    It may look differently, but usually like this
    But sometimes they do not install it.
    One more hypotesa - pedal pin is rusty and when you release the pedal pins stays stuck.
  10. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Ouh, ATC valve... (ASR valve in Europe). Faulty valve may brake rear wheels.
  11. Puller810
    32
    15
    Jan 17, 2011
    I will look at it tomorrow thanks for the ideas guys.
