99 international 9900 a/c problem
Discussion in 'International Forum' started by Bigrigger85, Aug 3, 2014.
  1. Bigrigger85
    Bigrigger85 Bobtail Member
    Have had everything replaced on system and after pulling vacuum and recharging the a/c works like a meat locker when sitting and idling for bout 30 minutes all the r134a blows out the blow off on compressor. It acts like it builds to much pressure. Any ideas. And another ? Is how many pounds of r134a should it take
  3. Old Man
    Old Man Road Train Member
    4,597
    13,469
    Apr 3, 2009
    Oklahoma City, OK
    High pressure cut off switch?
  4. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Replace comp. with new not rebuilt, before it blows up and fills system with scraps of steel.
  5. purpleprime
    purpleprime Medium Load Member
    681
    720
    May 30, 2013
    spickard, mo
    Maybe its not building to much pressure maybe that blow off valve is bad releasing at a lower pressure than it should
  6. Bigrigger85
    Everything was brand new no rebuilt junk
  7. Bigrigger85
    How many pounds of r134a should it hold
  8. BeenJammin
    BeenJammin Light Load Member
    256
    118
    Dec 17, 2013
    If I remember correctly, somewhere around 2.75 lbs. You should have a sight glass on your receiver drier for that system. When engine fan is off, charge it until sight glass clears and stop charging immediately, when fan kicks on, within a few seconds you should see bubbles pass through sight glass and then clear back up quickly.
  9. baha
    4,137
    2,835
    Jul 25, 2013
    ga
    ? Is the new comp. cuting off then back on again after it starts blowing cold? AT idle it should cut off and cycle to keep it from iceing up an over pressure the system, themo. is inside heater box it is a 2 screw replacement, If your truck has a rear sleeper a/c blower box it will take a little more than 3lbs waching sight glass for the bubbles to stop will give you the sign to stop filling
  10. BeenJammin
    256
    118
    Dec 17, 2013
    I'm not here to argue with you, but I think that year model has the lower profile hvac box and uses a low pressure ccot switch on the underside of it to cycle compressor from freeze up. I could be wrong, no doubt.
  11. Heavyd
    Heavyd Road Train Member
    7,752
    6,186
    Feb 4, 2009
    Sounds like the engine fan is not coming, and you have an APADS module. On systems without an APADS you have both a fan pressure switch to turn on the fan, and a high pressure cutout. I doubt both switches are bad. With an APADS module, there is only one switch which may be stuck. Either way, your compressor is being left on when high side pressures are too high.
