Hi All when we have been having a problem with the truck going in to shutdown mode. It will trun on the fan and light then go into shutdown. It will not start beeping like normal in a shutdown mode we think that it could be the Tps sensor dose that sound right to anyone.
99 International shutdown problems
Discussion in 'International Forum' started by petersonstrucking, Jan 10, 2012.
Would be best to scan for trouble codes and monitor live data to properly access the problem.
Have you checked the anitfreeze level?
Also good to check and clean all ground connections. -
Fan and check engine light coming on is probably the ECM seeing too high of coolant temp, too low of coolant level or too high oil temp. You engine is programmed for shutdown protection. The coolant temp gauge is feed from the ECM, so if your temp shows normal there it is either coolant level or oil temp. If you have an oil temp gauge it has it's own sensor and the ECM reads oil temp from a different one, so you may still have high oil temp. Until you confirm the problem is electrical or a sensor treat your engine like it may have a mechanical issue. You will have to get the code to see what is going on.
