99 kenworth w900 won't move unless power divider engaged.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by n1xrf, Feb 28, 2016.
  1. n1xrf
    n1xrf Light Load Member
    166
    32
    Jul 18, 2011
    somewhere in the USA
    I have a 99 Kenworth w900 with ds404 axles. We had one of our drivers move the truck around the yard and managed to get it stuck. Since then the only way to get it to move it to lock the power divider in. With it disengaged you can watch the driveshaft from the transmission to the front drive turn but with no drive wheels turn. If you lock it it the front axle will now drive. What could my problem be? I already foresee that I will have to pull the power divider, and possibly the front carrier. Any help before I tear into this is much appreciated.
  3. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    Did the driver spin the wheels a lot without the power divider locked in and did you hear an noises that were out of the ordinary? Unlocked, does the driveshaft to the rear diff spin and not put power to the wheels or do you not have any movement past the front diff?
  4. CasanovaCruiser
    CasanovaCruiser Road Train Member
    1,712
    2,669
    Jun 2, 2015
    Indiana
    I can't imagine the front diff being completely blown that badly but it's the only thing that comes to my mind
  5. TampaTony
    TampaTony Medium Load Member
    322
    340
    Dec 13, 2015
    You have blown out the rear end, probably the front.
  6. joe016
    joe016 Light Load Member
    120
    29
    Jan 23, 2016
    Yup just like Tampa say rear end out did he engage the lock when it was spinning.
  7. IH Truck Guy
    4,255
    48,588
    Mar 2, 2008
    Purgatory
    Or you snapped a axle shafts .
  8. ODR
    ODR Light Load Member
    66
    48
    Sep 30, 2013
    Tompkins, Sk
    I suspect the back diff. Drop a little oil out each and that will tell you where the problem is
    areelius Thanks this.
  9. wore out
    wore out Numbered Classic
    15,709
    189,880
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I am putting my money on a broke axle.
  10. AModelCat
    156,931
    Either that or something in the front drive axles is toasted. Does the truck have diff locks? If so, lock in the front drive axle only. If it moves, broken/damaged axle. If not, the differential itself is damaged. If you have no diff lock for the front axle, the only way to know for sure what's toast is to start pulling the axle shafts. If they're good, you'll have to pull the diff.
    Edit: when the shaft from the transmission turns and the truck doesn't move, does the inter axle shaft turn or not? If it does, rear drive axle, if not, the problem is in the front drive axle.
  11. strollinruss
    strollinruss Road Train Member
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    That's what I was gonna say. Probably an axle. Easy fix.
    Bean Jr. Thanks this.
