99 kenworth w900 won't move unless power divider engaged.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by n1xrf, Feb 28, 2016.
  1. wore out
    wore out Numbered Classic
    16,189
    196,278
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Unless I was unreachable he would be kickin rocks this morning. Not for the break down, but for not saying anything about it.
    Ruthless Thanks this.
  3. Oxbow
    Oxbow Road Train Member
    12,949
    134,354
    Nov 24, 2015
    Axle would be my first guess as well.
  4. Oxbow
    12,949
    134,354
    Nov 24, 2015
    There is a chance that he didn't know if he had left the diff lock in when parked (trying to give the benefit of the doubt here).
  5. n1xrf
    n1xrf Light Load Member
    166
    32
    Jul 18, 2011
    somewhere in the USA
    Power divider was not left engaged. He is now unemployed. Got tired of him tearing @&$) up and not saying anything. Anybody want a window licker that's real good at breaking things, and not telling anyone about it??
    cnsper and strollinruss Thank this.
  6. Cory wood
    Cory wood Medium Load Member
    335
    162
    Nov 7, 2015
    Axle is probably not the case of the truck moves with diff lock engaged. If it were a rear axle the interaxle shaft would spin and the truck would not move. If it were a front shaft the rear would still move the truck with difflock disengaged. Being that you have to lock the diff to get it to move I am guessing the thru shaft is stripped or the parts that slide over the through shaft that the spider gears turn is broken and just spinning inside the power divider, that would still allow the front to spin when it is engaged and transfer power.
  7. strollinruss
    strollinruss Road Train Member
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    No telling how long it's been like that. Has h been with you long? I'd have a hard time keeping that hand on.
  8. wore out
    16,189
    196,278
    Jun 5, 2013
    Explain that in a little more detail
    haycarter Thanks this.
  9. n1xrf
    166
    32
    Jul 18, 2011
    We got the truck about 2 months ago. He has was with us for about a month. Before he drive it the other day, I was the last one to drive it. When I drove it before him, there was no problems with either the axles or the inter axle lock. This truck does not have diff locks. My boss has decided after it gets fixed he is selling it because he doesn't want or thinks he needs a sleeper truck. He's wanting another day cab. I hate to see it broken or that he's selling it now.
  10. Cory wood
    335
    162
    Nov 7, 2015
    Inside the power divider you have the input gear that has the sliding clutch and the spider gears And the gear that turns the front pinion and ring. The front driveshaft spins all of that, the spider gears in turn spin the teeth on part that slides over the thru shaft. If the teeth on the spider are bad, if the part that slides over the thru shaft is bad than the input will still spin the gear that turns the front rearend. My guess is something right there is broken and the gear and sliding clutch are fine so the front will engage. That's how a 404 works. Pull the power divider and I have a feeling that's where the broken parts are, usually we see the spider gears broken.
    truckdad, n1xrf and AModelCat Thank this.
  11. Bean Jr.
    Bean Jr. Road Train Member
    5,518
    9,826
    Mar 30, 2014
    Clearly that is not how a power divider works. It is also called an "inter-axle differential lock". Essentially when it is not locked, it acts like an axle differential, allowing the wheel that doesn't have traction, to spin, and not putting an power to the one that has traction, except in this case it is the whole axle as opposed to just the wheel. When it is locked, then power goes to both axles, just like a locking rearend puts power to both wheels.
    The weakest link in this chain would be either of the axles.
    wore out and AModelCat Thank this.
