99 or 97 kenworth w900l
Discussion in 'Experienced Truckers' Advice' started by wyfarmer, Nov 21, 2013.
  1. wyfarmer
    wyfarmer Bobtail Member
    I have a chance to buy either of the two trucks mentioned. One is a 99 kenworth w900l with a brand new overhauled detroit and a 10 speed. some of the things it will need to be road worthy are 4 drive tires and thats about it. The other truck is a 97 w9 with a 550 cat and a 13 speed it has a few more bells and whistles than the other and it needs nothing it is ready to roll now. I will be using these trucks on my ranch for hauling crops and cattle to market and around the place. my question is what truck would be a better buy. they want 18000,00 for the 99 and 23000.00 for the 97. I am kind of leaning towards the 97 but i think the 99 is also a pretty good buy but not sure so i thought i would ask the crowd that has way more experiance than me. Sorry for the long winded post and i thank you for your input.
  3. CougFan
    CougFan Light Load Member
    268
    154
    Dec 20, 2012
    I would say it depends on how far you are planning on running. If its just local get the cheapest. Whats the HP rating on the DD? It seems to me to be the better choice, even with it needing drives, as with the DD and overhaul it might have better resale.
    If your heavy and have lots of hills you might be better off with the Cat and 13speed, but who knows if its reliable?
  4. wyfarmer
    I should add that the the cat has 300000 on it since last rebuilt both trucks are around the 1.2 million mile mark total on the truck. And yes I live in the mountains very direction I go I have mountain passes. I will be loaded at 80000 all the time as we'll
  5. CougFan
    268
    154
    Dec 20, 2012
    With all of that, I would probably go with the cat. Keep your foot off the gas and use the splitter to keep the RPM's in the sweet spot.
    I haul 105,000 line haul, and being heavy with hills the 13 speed does make a difference. You should ask them to put the good drives on that one for you. (Never hurts to ask lol).
  6. CougFan
    268
    154
    Dec 20, 2012
    Just make sure that the brakes are good, and that it has a Jake on it.
  7. fld
    fld Medium Load Member
    383
    258
    Nov 24, 2012
    The only problem with the cat is that it is very expensive to rebuild. Sooner or later that day.is going to come.
    You could always get the Detroit, get some performance upgrades, put in an 18 speed for your mountains. Then you would have a truck with new engine, new trans and clutch, and a truck that you have less money into that is set up the way that you want. You could go a loooong time without worrying about your driveline. Just a thought.
  8. popcorn169
    popcorn169 Road Train Member
    2,194
    1,714
    Sep 5, 2011
    state of confusion
    Living in the mountains I would also take the cat. If it has only about 300000 miles on the rebuild it should be good to go. You did not mention what rears are in each. That can be one of the deciding factors. If you have a rear that is geared wrong you have not accomplished anything.
  9. wyfarmer
    They have 3:70 rear ends in them. I'm just thinking that maybe the 13 speed will give me alittle better performance in the mountains and also the bigger horse power. The detroit is set at 470 I believe. Both have good brakes the 97 has better tires. Thy both have tall 24.5 so I see that as a plus.
  10. CougFan
    268
    154
    Dec 20, 2012
    Go with the cat. Low Pro tires would actually give you a little bit more pulling power, but with 550 its kinda a moot point.
  11. wore out
    wore out Numbered Classic
    15,407
    185,976
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Another thought is the detroit is a fresh overhaul. If buying a fresh overhaul I like to see 30000 mile at least. If it wasn't done right it usually shows by then. New parts are useless when installed improperly. The CAT has enough miles to show its rebuild will hold. I have seen many new engines fail due to sloppy work.
    If you buy the detroit put drives on it performance upgrades and an 18 speed you will have at least another 6000 in it.
    True the CAT is older and a little more money but its rigged to do the job at hand. And the tall rubber will be a plus for what you do. We run a 2000 model 379 with a cat and 18 with 3.36 and my old 359 with a cat and 13 with 3.55. Haul grain with the 379 and cattle with the 359, both are heavy all the time and the tall rubber is nice for clearance.
