Hi y'all , I have a 3406e cat with oil loss!! It use about 2 gallions every 300 miles!!
any help will be Appreciate !! And it has over million miles!!
Thanks
99 Pete with a 3406E oil loss!!
Discussion in 'Peterbilt Forum' started by travis wal, Oct 28, 2013.
First?? Can u see oil on around motor??
2d?? Is there bubbles on ur oil dipstick?
3d?? Does it look like there is oil or film in radiator?
Could be # of things--little more info maybe we can help -
Thanks for the fast respond ,everything looks good!! But about 2 weeks ago we lost oil psi, and it turns
out we had a pluged oil filter , so we cut it open and found , almost like broken glass Residue that pluged our filter!!
Thanks -
You may want to get it to a cat dealer. Sounds like it is inframe time, if there are no visible leaks. Last thing you want is to loose a rod and wipe out a crank or block.
A friend of mine had to replace his filters often for the same reason. He had a bad ring. The give away to that was excessive blow by
Thanks , it's getting rebuilt as of two days ago !!
Part of the problem was we had to replace a oil cooler
and it started coming apart!! Aftermarket one by the way!!
It lasted about two month, before we started notice it in the oil filfilter
thanks for the input
