99 Peterbilt 379EXHD Clutch issue
Discussion in 'Peterbilt Forum' started by localboy89, Feb 3, 2014.
  1. localboy89
    localboy89 Bobtail Member
    4
    Central Illinois
    Hello, have a 1999 Pete extended hood that the clutch does not return all the way back anymore. It goes down to the floor like normal, but have to use my left foot to bring it back up so I can use the cruise and jake. Was thinking clutch return spring broke, anyone know where it is located? Any help is appreciated. Thanks
  3. MPH2
    MPH2 Light Load Member
    244
    70
    Nov 20, 2012
    Strawberry plains, TN
    Does it come up normal at all like to a certain point? Do you feel it slipping at all if so it could be the fingers on the pressure plate. If it is just the inch or so it's probably the spring on the pedal
  4. localboy89
    4
    Central Illinois
    Mph2, it does return to a certain point and does not slip. Last few inches just no return at all.
  5. mslashbar
    mslashbar Medium Load Member
    602
    813
    Jul 22, 2009
    elizabeth,co
    The return spring is under the cab, right under the drivers side floor board, hooked into the clutch linkage.
  6. localboy89
    4
    Central Illinois
    Ok nothing there so problem solved. Thank you all!!!!!
  7. heuchert
    heuchert Bobtail Member
    7
    Alexnadria, MN
    I was having the same problem with mine also. I will have to check mine now thanks for the help
  8. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    There are three greasing points on that linkage system..... Often overlooked.
  9. mtoo
    mtoo Road Train Member
    1,936
    4,514
    Jan 15, 2011
    Retired on bended knee
    What beltrans said. It takes a long time but if these zerks are not greased that is the outcome.
