9900i Radiator
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by LB9900i, Jul 3, 2020.
  1. LB9900i
    LB9900i Bobtail Member
    14
    Apr 8, 2020
    Has anyone ever installed a "bigger" than stock radiator in a 9900i International?
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Y do you need more cooling capacity. If so call Pittsburgh power
  4. LB9900i
    14
    Apr 8, 2020
    I'm going to need more cooling capacity if I do the upgrades I'd like to.
  5. bad-luck
    bad-luck Road Train Member
    3,375
    6,247
    Nov 16, 2013
    Baltimore, Maryland
    You can get a radiator rated for or above the hp that you have.
  6. Rideandrepair
    17,445
    56,610
    Aug 8, 2015
    Try American cooling solutions. Just get the copper 4 row. My Classic was $900. Good radiator
  7. Heavyd
    Heavyd Road Train Member
    7,811
    6,264
    Feb 4, 2009
    Yes, I believe Ride is correct. With most trucks, a higher and or wider rad will usually not physically fit. What they do is make them thicker with more cooling rows.
