A.C. and heater problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jeffman164, Jul 28, 2022.
  1. jeffman164
    jeffman164 Medium Load Member
    563
    491
    Dec 4, 2012
    Hello. I have a 1999 International 9200. Mechanic just put new on/off switch, compressor and clutch in. Filled freon also. Going down the road AC will be cold and then it seems to be just blowing outside air. Then after a while air gets cold again. The strange part is that in the winter , I am quit frequently adjusting my temperature setting. Blower blows hot and then not so hot and so forth. Any connection or is my truck just possessed.
  3. Big Road Skateboard
    4,394
    20,915
    May 2, 2021
    A/C part sounds low on freon. Really need knowledgable eyes on some gauges.
    Heater issue most likeky a different issue
  4. jeffman164
    563
    491
    Dec 4, 2012
    Not sure if the gauges would help if they check it when the cold air is on the working again cycle. Intermittent.
