A/C Clutch constantly running in kenworth. Is this normal or should it be kicking off
Discussion in 'Kenworth Forum' started by kimbo7, Apr 15, 2013.
  1. kimbo7
    kimbo7 Bobtail Member
    9
    A/C clutch question, is the a/c clutch that is on the compressor suppose to constantly run or should it kick off from time
    To time? I was told by a mechanic that it is suppose to stay on. But to me that seems like it would make it burn up. Your advice on this is greatly appreciated.
  3. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
    if your ac is on or defrosters on it would run but normally short periods intill it flips the high pressure switch
  4. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    the high pressure switch triggers the fan. unless it has a second switch. to which i haven't driven many trucks that actually had 2.
    my w9 only had one. for the fan. and yes, it ran all the time untill it got low on freon. or the outside temps were below 80.
  5. losttrucker
    losttrucker Road Train Member
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    The compressor should cycle on/off
    simplyred1962 Thanks this.
  6. carrkool
    883
    495
    May 10, 2012
    adah, pa
    every ac system I have worked on rig wise has had either 2 switches or one that controlled both the ac clutch and fan
  7. fifthwheel07
    fifthwheel07 Bobtail Member
    35
    13
    Salt Lake City,Ut
    Check it out. Turn off AC, wait a few min to let sides balance out or it will likely go off on high head pressure if compressor is engaged with out allowing time,there is a high head pressure switch to prevent this. Set to full cold turn on AC ,idle will go up a few rpm to compensate for compressor drag and engine fan will kick in providing air flow over coil ,when desired temp is reached thermostat will cut off compressor. So depends on outside ambient temp how long compressor runs. Turn off AC ,leave cab fan blower on. Engine fan should cut off if not called for by eng temp . The air exiting the registers should be noticeably warmer if the compressor is shutting off. And it's not supposed to run all the time, that would wear it out faster, does a window AC compressor run all the time.
  8. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    The a/c compressor should cycle on and off, the "freeze switch" in the hvac unit controls the cycling when the system is running. If it runs steady when the system is on could be low on charge or a stuck freeze switch, if it runs when the system is turned off it most likely a stuck relay in the pd box.
    What year is it as KW changed a few componets through the years.
  9. leksi
    leksi Bobtail Member
    2001 kW how Mach frion need the A/C system end the cab fan stop working any suggestions I appreciate
  10. rollin coal
    rollin coal Road Train Member
    13,446
    27,409
    Mar 29, 2008
    TN
    Might be a sticker on you CAC or somewhere on left front engine area telling how much freon. I think mine takes 2.5 lbs but not 100% sure on that.
    leksi Thanks this.
  11. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    The amount of freon needed is different between a day cab and a sleeper.
