a/c compressor fuse blows
Discussion in 'Trucks [ Eighteen Wheelers ]' started by VARITHMS, Sep 22, 2016.
  1. VARITHMS
    VARITHMS Medium Load Member
    476
    106
    Nov 26, 2009
    HOUSTON
    I have a 2015 t800 day cab and the fuse/breaker for the air conditioning compressor gets really hot and trips. The fuse will cool off and the a/c compressor will work again and cool the truck off. The fuse, and relays for everything have been replaced. I can switch out the fuse with another and it will work for another two hours or so. The heater does not work either. The electric valve that controls the coolant flow to the heater core works.
    It have spent almost as much time at Kenworth of Houston (performance truck) as we have had it. It is not going back to them. 1200.00 later and it still does the same thing. They have admitted there is a problem, but cant find it. I'm on my own now, any help would be great.
    I'm going to replace the a/c compressor clutch tomorrow.
    If that doesn't work the hvac controls on the dash, then the coolant valve.
  3. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Does your blower fan push air out the vents? You say heater not working either.Kinda sounds like some semi -corroded or melted power wires maybe from the firewall to the blower motor or dash control unit.Compressor shouldnt have anything to do with heater not working.I would start checking wires.JMO
    VARITHMS Thanks this.
  4. AModelCat
    154,621
    Why are you paying? Don't you still have warranty?
  5. VARITHMS
    476
    106
    Nov 26, 2009
    HOUSTON
    The 250k mile warranty is drivetrain only.
    The blower works great. The flow control gates for the direction also work.
  6. VARITHMS
    476
    106
    Nov 26, 2009
    HOUSTON
    Warranty has exceeded the mileage
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    Cut the wire and put a 25? amp fuse, not breaker, in the feed for the clutch first. I would hate to replace a compressor that was not the problem. Just a thought open for correction and other thoughts.
  8. VARITHMS
    476
    106
    Nov 26, 2009
    HOUSTON
    Not a bad idea. I was going just to replace the clutch on the compressor, not the whole unit. I think the clutch is $30-$40
  9. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Very common for a/c compressor clutches in ISX engine to draw more than 3-4 amps when they go bad. I think it is because of where they are mounted on hot side of engine. Replace compressor.
    VARITHMS and BoxCarKidd Thank this.
  10. BoxCarKidd
    4,418
    6,432
    Aug 26, 2014
    Replace compressor not clutch on rotary compressors because the failure rate is high afterwards. Just my experience. I do not quite understand the 3-4 amp draw and how that is tested. Appreciate if you could explain that a little bit.
