A/C issues, 2001 379
Discussion in 'Peterbilt Forum' started by bowtie_guy, Jul 17, 2011.
  1. bowtie_guy
    bowtie_guy Light Load Member
    202
    49
    Jan 29, 2010
    Sudbury, Ontario
    I'm thinking the evaporator is freezing and wanted others input.
    Driving around a/c will be cold then it slowly gets warmer till it basically stops. Originially i tried playing with the hot/cold dial and sometimes it would help by going to hot then going back to cold.
    Finally I tried just turning the a/c off for approx 30 min then when i turn it back on it's cold again for a while.
    I've also tried fan on higher and the dial set to a little warmer but it still stops working after a while.
    Just wondering if anyone might have an idea or suggestion? Obviously want to try myself before putting truck down at a shop.
    Thx
  3. Roadhound
    Roadhound Light Load Member
    283
    113
    Jan 31, 2007
    Tennessee
    If the system is full of freon, it sounds like possibly the expansion valve is sticking.
  4. WMGUY
    WMGUY Road Train Member
    1,684
    800
    Jan 1, 2011
    Nine Mile Falls, WA
    are you in a high humidity area?
    are you running a max a/c?
  5. bowtie_guy
    202
    49
    Jan 29, 2010
    Sudbury, Ontario
    When you mention the expantion valve that kind of makes sence, have seen those go bad before. Wish i had access to a ac machine just to watch the pressures on the high and low side. Easy to tell then.
    It has been pretty humid and i have tried both regular and max a/c.
    Guess i might have to bite the bullet and go to a shop... :(
    Any chance someone knows how many lbs of freeon the system should have in it??
  6. Ryanr
    Ryanr Light Load Member
    71
    14
    Mar 6, 2009
    ontario
    If you have a 379 with a bunk it holds 5.5lbs.Mine did the same thing.Your front ac(cab) uses an orfice tube instaed of an expansion valve it is located it the high presure line right were it goes through the firewall,u have to evac the system to replace this.the bunk ac uses an expansion valve but won't cause the front cab to stop working.Your problem is the orfice tube or the thermastat switch.The switch can be replaced without evacing the system.It is located in the evaporator it's a switch with two wires on it with a long wire the pushes through the centre of the evaporator and senses the temp of the core and tells the compressor when to cycle on or off depending on the temp.Its not telling the compressor to shut off so its freezing up,the pressure gets high in the high pressure line than the comp shuts off.a GOOD WAY TO TELL IS WHEN YOUR SYMPTONS START HAPPENING WHEN YOUR PARKED TURN ON THE HEAT FULL AND GO OUTSIDE AND SEE IF YOUR AC DRIP TUBE IS PISSING PUT LIKE A GARDEN HOSE,THEN U KNOW ITS FREEZING UP FOR SURE.
  7. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    do you have a dryer unit that has a little siight glass/window on the top of it? Lots of bubbles are a sign of a low charge, which could give you this kind of results too.
  8. Ryanr
    71
    14
    Mar 6, 2009
    ontario
    that year will use an acumulator dryer on the low side going back to condensor,no sight window. Those styles are used on receiver dryer high side.
  9. Kgamero19
    Kgamero19 Bobtail Member
    Hey im new here im having same issue replace my orifice tube and it blow cooler than it used to be but it still freezing. I have same truck as u my question is how do i get to the thermostat switch or how does it look like so i have kind an idea what im looking for once i work on it again. Thanks.
