A/C leaking water into cab?
Discussion in 'Ask An Owner Operator' started by bigNATURE, Aug 24, 2014.
  1. bigNATURE
    bigNATURE Medium Load Member
    304
    86
    May 5, 2013
    Texas city, tx
    Have any of you had the a/c blower fan area under the bunk leak water into the cab?
    and if so what do you do to fix it?
    im going to thermoking in a few days in KC to get a new condenser for my tripac unit, it's leaking refrigerant.
    i was going to ask them to blow out the condensate drain, or whatever that pipe is that allows the water to drain.
    my truck was parked for about 2 months maybe something like wasp nest or spider web got up in that water drain tube?
    Any insight or suggestions on this matter would be very helpful and greatly appreciated!!
  3. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    the codensate drain is probably plugged most the time they are a flexible rubber hose that you can squeeze to remove a blockage sometimes not quite that simple though. and need to be manually cleaned and flushed out.
    Cetane+ and bigNATURE Thank this.
  4. bigNATURE
    304
    86
    May 5, 2013
    Texas city, tx
    That's what I'm hoping. Water in the cab is no fun,
  5. snowwy
    snowwy Road Train Member
    20,532
    13,268
    Jul 6, 2009
    if you can't pull the hose or whatever to clean it out. try using something like a long screwdriver or whatever to clean it out. it's what I did to the front unit once. in the truck I was driving at that time.
    bigNATURE Thanks this.
  6. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    Or possibly the drain hose has come off or broken. Have you actually looked at it?
  7. bigNATURE
    304
    86
    May 5, 2013
    Texas city, tx
    Yeah, I took apart the whole unit that houses the two condensers under the bunk, and couldn't find the top of the drain pipe for some reason. I see where it is outside, underneath the cab. But I was hesitant to blow air UP thru there or to stick anything UP thru there.
  8. bigNATURE
    304
    86
    May 5, 2013
    Texas city, tx
    Didn't want to damage anything in that pipe I don't know about, like a butterfly valve or something of that nature,
  9. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    I don't have an APU, but I'm getting water in the back of the bunk. Where does the main ac drain on a FLD classic?
  10. xsetra
    xsetra Road Train Member
    5,103
    6,964
    Aug 21, 2011
    Classic has a drain in the front under dash on passenger side. Also has a drain under bunk on passenger side.
  11. OldHasBeen
    OldHasBeen Road Train Member
    1,269
    924
    Dec 16, 2010
    With my Toyota Camry I used a clothes hanger to clean out my drain tube, dirt dobbers had done a job on it.
    After I stuck it up into the hose water started coming out slowly, after that bent over the end of the clothes hanger wire to make it a bit larger & did it again, them the water ran out very fast.
    Which in doing this you will want to be careful, of course if the hose is in good condition it will stretch a bit without doing any harm.
