A/C problem
Discussion in 'Volvo Forum' started by 325TahoeSS, May 21, 2013.
  1. 325TahoeSS
    325TahoeSS Light Load Member
    150
    71
    Feb 11, 2012
    Roma, Tx
    I changed my a/c compressor, dryer & both expansion valves! I we did the vacume and put the oil & free on in! My ac is cooling but it's NOT COLD COLD! It's seems fresh only! Anyone have an idea on what going on?
  3. Fatboy42
    Fatboy42 Light Load Member
    281
    389
    Feb 9, 2011
    Indiana
    Was orfice tube replaced can be slightly clogged
  4. Boka
    Boka Light Load Member
    199
    113
    Nov 6, 2012
    You might have a leak somewhere. Was it cold at first when you put freon in it?
    Also check if your coolant valve is open, some people close it through winter...
  5. 325TahoeSS
    150
    71
    Feb 11, 2012
    Roma, Tx
    No leaks & it's fully charged!
  6. nasriza
    nasriza Road Train Member
    2,404
    2,074
    Feb 1, 2013
    Chicago, IL
    Check the heAt control valve it's possible it stuck partially open the other possibility is its not fully charged in a 780 we usually put 3 lbs 12 oz inside to get it just right
  7. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    How much oil did you put in? Too much will hamper the freon........
    Throw me your pressures along with the ambient at time taken and I'll give it a shot........
  8. tw1005tx
    tw1005tx Light Load Member
    60
    18
    Feb 24, 2011
    The new compressor would have come with oil in it already, you said both expansion valves replaced wouldn't think there would be a orfice tube. Heat coming from somewhere (pressures as Chalupa mentioned),fan not coming on, the list is long.
  9. chalupa
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Beg to differ tw....... new comp can't come with oil loaded as every system ( application ) is different. Oil in not only for comp, it's for the entire system lubrication hence the difference in amt needed. ( day cab vs sleeper )
    If you bought a comp with oil in it, it's been installed or filled with intention to install by end user. New are shipped with a squirt for moisture control but that's it......
    JME
  10. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Every compressor I have ever installed has oil in it. The last one I installed (Sanden) from Peterbilt said in the box "compressor is prefilled add 1 oz of oil to accumulator at install".
    The compressor should tell you how much oil is in it and your A/C book should tell you total system amount.
    chalupa Thanks this.
  11. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    Did you have compressor failure? Did you flush lines and is the condenser clogged? Is the evaporator clogged with dirt? Just a few things. Make sure your Compressor Clutch is engaged also.
