A/c question...
Discussion in 'Questions From New Drivers' started by Krashdragon, Jan 28, 2014.
  1. Krashdragon
    Krashdragon Medium Load Member
    651
    305
    Apr 10, 2012
    Cleburne, Tx
    I was reading somewhere about a driver that complained that the a/c didn't work. The mechs said it did.
    Later in the post it said something about he didn't "know how to turn off the water valves on the truck" so the a/c would blow cold instead of hot.
    Is this common? Like where would I find the valves. On a 2000 Freightliner..... ( I think....)
    Y'all stay warm. And safe.
    mary
  3. Moosetek13
    Moosetek13 Road Train Member
    14,698
    18,479
    Nov 1, 2010
    Burnsville, MN
    The valves are located behind the engine, under the transmission, around the flux capacitor, and through the thermocouple.
    Simple, really.
    WitchingHour, blairandgretchen and x#1 Thank this.
  4. x#1
    x#1 Road Train Member
    1,773
    1,104
    Dec 24, 2009
    Cherokee County, Alabama
    prob a detroit so the valves,plural,will most likely be on the right(passenger) side and most likely will be the valves that look like an outdoor house faucet.you could have lever type valves but i doubt it.they control the coolant flow basically.experiment with turning them on/off and regulating the heat or lack thereof. I never really open mine completely up,i do as i type this now but what a freak winter,simply because it gets too hot for me in the truck.
    you'll get several interpretations i am sure.i was attempting to keep it simple.look under/over/beside everything along the side of the engine as some of the valves are difficult to actually spot and then get to.
  5. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    I'll be honest in saying I'm not the most well-versed in Detroits, but it seems to me like they're talking about valves to cut off engine coolant/antifreeze flow to the heater core... doing this improves the effectiveness of air conditioning, as the blower motor, (AC) evaporator, and heater core are typically all housed in a single HVAC compartment. Such a valve causes the hot engine coolant to bypass the heater core, and keeps that heat out of the HVAC compartment. The difference is the AC blowing cooler.. not the difference between the AC blowing cold air and not blowing cold air at all.
    AC refrigerant works through heat exchange... the refrigerant absorbs heat, becomes pressurized and superheated, then that heat exchanges to the ambient air which flows through the condenser fins, thus causing the refrigerant to rapidly lose heat and become 'cold'. Then that depressurized refrigerant flows back through the system, the blower motor blows air over the evaporator, etc. Your AC will be much more effective in, say, 85 degree weather than in 105 degree weather, as the higher difference in temperature between the superheated refrigerant and the ambient air allows for a more rapid and efficient heat exchange.
    I don't know the full story here, but if the AC wasn't blowing cold air at all, I'd be willing to bet it was something more than a bypass valve. There are a multitude of things which could go wrong with an AC system, and the troubleshooting process is a bit of a PItA.
  6. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    I have never had to mess with any Valves to get my AC to work properly.
    Of course the oldest truck I have driven was a 2007 Volvo.
    The one time the AC didn't work right...well...Something was broke.
  7. TripleSix
    129,839
    Passenger side of the engine. You should see some hoses about the same size of a garden water hose running along the frame rail. My truck has 2 valves. One goes to the cab, the other to the sleeper. Close off both valves and that AC blows cold enough to frost the windows on the inside.
  8. Powder Joints
    7,687
    7,780
    Sep 25, 2007
    Rosamond, SoCal
    If you have to mess with the heater shut off valves they need to charge the AC.
    379exhd Thanks this.
  9. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    My thoughts exactly!!!
  10. WitchingHour
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    They need to do a full system performance test. People automatically assume the refrigerant needs to be recharged always when, in fact, insufficient cooling can be caused by a number of things... blockage in the system, inadequate airflow across the condenser fins, saturated desiccant in the receiver-drier, excess refrigerant or PAG, etc. And if the refrigerant is low, there's a leak somewhere, and that needs to be isolated and fixed.
  11. Krashdragon
    651
    305
    Apr 10, 2012
    Cleburne, Tx
    Lots of good info, thanks.
    Wasn't my truck, but thot it would be good info to know...just in case.
    Thanks
    Mary
