A/C repair question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by IowaDoorSwinger, Jun 7, 2024.
  1. IowaDoorSwinger
    IowaDoorSwinger Bobtail Member
    4
    5
    Jun 7, 2024
    I replaced most of the a/c system. the clutch on the compressor was not kicking in and was losing refrigerant somewhere around expansion valve. Replaced compressor, dryer/filter, high and low, switches, and expansion valves. Finally got it to hold vacuum for an hour, no psi lost. Charged the system back up to spec. Watching the guauges on the manifold when truck is running, the low side is about 32 psi but the high side will run all the way up to 450 before I shut it off or manually turn on the engine fan, then it will drop back to 150psi. Also the gauge on the high side will start fluttering above 300 psi. A/C is blowing about 55 degrees now.
    Could there be a problem or blockage in the condenser? And shouldn't the fan kick on at 300psi?
    Rideandrepair Thanks this.
  3. Big Road Skateboard
    6,708
    37,774
    May 2, 2021
    Yeah, fan should kick on 300-325.
  4. IowaDoorSwinger
    4
    5
    Jun 7, 2024
    that's what I thought. the pressure switches are both new, but they came from Napa. wondering if I should make the 150 mile round trip to the dealer and get OEM.
  5. Big Road Skateboard
    6,708
    37,774
    May 2, 2021
    What truck? How did they look up the part #'s
  6. IowaDoorSwinger
    4
    5
    Jun 7, 2024
    I brought the old switches with me and matched them up. that's the only way they can do it. my F/L dealer gets a little schitty about giving out part numbers if he knows your not going to buy from him
  7. IowaDoorSwinger
    4
    5
    Jun 7, 2024
    forgot. Its a '15 wester star 4900sb
  8. Rideandrepair
    17,442
    56,582
    Aug 8, 2015
    Fan should be coming in as you said. Make sure the switches you bought are hi and lo switches, not hi/lo switch and a fan switch. Any parts book or counter can tell you the fan switch spec. Might find a catalog online at Truck air .com. Assuming it blows cold with fan manually engaged. I’m only guessing, must be a separate fan switch that’s bad. Find the fan air solenoid. Follow the air line from the fan. I’d be looking for wires running to the fan solenoid. Follow them to find the fan switch. Inspect the wires and plugs while you’re at it.
    5UG Thanks this.
  9. 5UG
    5UG Light Load Member
    53
    46
    May 22, 2024
    I wouldn't bother with that trip. Try unplugging the high side pressure switch. The compressor should go off. If it does, the switch is probably bad, or not getting a good read due to a blockage before the pressure switch. Run your hand along the high side and feel for any cold spots before the expansion valve. Cold spots indicate a restriction. **Warning: the high side lines get hot in general, but extremely hot at high PSI. You may want to use an infrared thermometer instead of your hands.
    Let us know what you find, and we'll go from there!
    Regards,
    5UG
