A/C
Discussion in 'Peterbilt Forum' started by last 1, May 6, 2012.
  1. last 1
    last 1 Medium Load Member
    439
    184
    Nov 29, 2009
    I have a 2000 379 and today the A/C started to only blow thru the defroster (it is cold) no matter where I set the selector. I'm guessing defroster is default mod if something goes wrong. I'm thinking its the control panel on the dash, does this sound right? I sure don't want to buy one as I bet they are spendy and find out it it is something else. Is there a way to manually set the diffuser till I get what ever fixed? Thanks in advance for any help.
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Pull center dash panel and look down there is an actuator they go out a lot and a lot cheaper then the dash control I have also seen the door inside the a/c box break start with the actuator see if its moving with the selector switch if not see if tour getting power to it use a paper clip as a probe as to not damage the plug
    last 1 Thanks this.
  4. last 1
    439
    184
    Nov 29, 2009
    Thanks. I pulled the actuator but haven't checked to see if it was getting power or not. For now I just zipped tired the flapper where it blows out the dash vents. I'll check everything out when I get home later in the week.
  5. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
