a/c
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Superhauler, Jul 27, 2016.
  1. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    Ok, got a brain teaser. My ac on my w900 won't cycle and the evaporative core in cab will freeze up after a while on the outside not internally. Checked freon level, it is good. Changed high and low pressure switches and thermostat switch. The compressor still runs all the time won't cycle. Any ideas?
  3. passingthru69
  4. Superhauler
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    All new, new dryer, new lines new everything. Only thing original is the condensor.
    passingthru69 Thanks this.
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Does the compressor shut off when you shut the A/C off? If not, possibly the A/C clutch relay stuck on?
  6. Superhauler
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    Yes it shuts off when I shut the a/c off. Works great cooling the cab. Just freezes up after a while. Turn it off and watch the drain poor water out as it thaws.
  7. wore out
    wore out Numbered Classic
    15,532
    187,456
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    If you figure it out share some info with an ol pal. My red 359 is doing the same thing.
    Oxbow and Superhauler Thank this.
  8. AModelCat
    155,826
    Thermostat switch. You're talking about the one that goes into the evap core correct? Did you put the probe into the center of the core?
    Superhauler Thanks this.
  9. Superhauler
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    Yes stuck in the hole that is drilled in the tray.
  10. Superhauler
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    This truck has always had a fluctuating gauge when I hook the gauges up. But not enough to worry about. I'm just wondering if I need to put a new condenser on. Thinking maybe there might be some debri floating around in the system that is screwing with the presume switches. Thought maybe I had a bad conection, but have ruled that out.
    wore out Thanks this.
  11. AModelCat
    155,826
    Is it possible that instead of going down into the core, it bent and travelled around the side of it?
