A Clean Deck
Discussion in 'Experienced Truckers' Advice' started by 315wheelbase, Jun 30, 2015.
  1. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    Ok fellow drivers,,if you pull a flat, step or lowbed(RGN) it is very important that after you unload you clean your trailer deck and secure any dunnage or other equipment very good.
    Good deck haulers do this, it only takes a couple minutes to clean all the debris from your trailer deck,,if you have been off road (this applies to all trucks) and there is a lot of mud caked up around your wheels or packed ice and snow knock all of that off too,,Anything that falls off your truck can hurt or kill someone and in many places it can get you a big ticket.
    You do not want anything to fall off a truck or 4 wheeler and hit your car or truck.
    Couple years ago going west across I-10 in Texas a 4 wheeler pulling a 18ft open trailer dropped a toilet on the road, it broke in pices all over both lanes, I hit a pice of the porcelain and it hit my right fuel tank rupturing it,,So be a good example and after you unload clean off your trailer deck and secure all on your trailer be a true professional
  3. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    I lost a windshield to a empty lowboy going opposite direction .. He hit a bump just as we were meeting and rocks and dirt went airborne .. A golfball sized rock almost went through the windshield... Nice to see someone caring about other travellers and PEDESTRIANS TY
  4. rank
    rank Road Train Member
    9,918
    113,505
    Feb 11, 2010
    Climbed up on top of my load today...14 ft 6 in off the ground to measure height. Found a handful of 3/8" bolts someone left up there.
  5. brsims
    brsims Road Train Member
    5,296
    6,521
    Aug 8, 2009
    Meadville, PA
    I HATE have extraneous crap on my deck! Everytime I drop, everything gets put away. Lumber in rack, chains and straps in appropriate compartments, tarps in bins, bungees tucked away in compartment.
    That way, my deck is ready to go when I get to the next shipper. Only time I have to "work" prior to loading is if I need to set up coil bunks or set dunnage. And simce everything is where it's supposed to be, securing and tarping is a heck of a lot quicker and easier. I never have to tear the truck apart looking for equipment.
    Besides, an empty deck looks more professional in my opinion. And appearance is important to me. I'm still a flat rookie flatbedder, so sometimes I think I gotta work twice as hard to try and earn a bit of respect from my fellow flatbedders. Y'all are darned hard to impress!
    blairandgretchen and skellr Thank this.
  6. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    So now you have to worry about where those bolts were suppose to go!! Hope you load doesn't come unbolted going down the road, lol
    blairandgretchen, MJ1657 and rank Thank this.
  7. zinita17601
    zinita17601 Road Train Member
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
    First things first,some drivers need to learn to secure their loads before even trying to clean the deck,passed a milton flatbed driver on i80 today,a full load of railroad ties secured by 8 two inch straps.
  8. kylefitzy
    kylefitzy Road Train Member
    4,675
    19,366
    Aug 12, 2007
    Kansas city,Mo
    And? That is enough straps to secure 53328 worth of cargo assuming a regular 2" strap with a wll of 3333 lbs per strap. Length might be another issue but some people need to learn the regulations before they critique others securement.
    browndawg Thanks this.
  9. zinita17601
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
  10. zinita17601
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
    no is not a length issue,the load was in four bundles,each bundle had two straps on it.assuming the load is 44k,each bundle weighs 11k.2 straps eqauls 6666 lbs wll.federal regulations requires 80% forward movement tie downs that equals 8800 lbs so 2 two inch straps are not enough.
  11. kylefitzy
    4,675
    19,366
    Aug 12, 2007
    Kansas city,Mo
    The 80% forward movement is not an actual regulation but a publised result of a study that the regulations are based on. Only half of the weight of the cargo needs to be secured:
    Minimum Working Load Limit for Cargo Securement Devices and Systems
    The aggregate working load limit of any securement system used to secure an article or group of articles against movement must be at least one-half the weight of the article or group of articles. The aggregate working load limit is the sum of: One-half the working load limit of each tiedown that goes from an anchor point on the vehicle to an attachment point on an article of cargo; and The working load limit for each tiedown that goes from an anchor point on the vehicle, through, over or around the cargo and then attaches to another anchor point on the vehicle.
    Minimum Number of Tiedowns
    The cargo securement system used to restrain articles against movement must meet requirements concerning the minimum number of tiedowns. This requirement is in addition to complying with rules concerning the minimum working load limit. When an article of cargo is not blocked or positioned to prevent movement in the forward direction, the number of tiedowns needed depends on the length and weight of the articles. There must be - one tiedown for articles 5 ft or less in length, and 1,100 lbs or less in weight; two tiedowns if the article is -
    1. 5 ft or less in length and more than 1,100 lbs in weight; or
    2. greater than 5 ft but less than 10 ft, regardless of weight.
    - See more at: http://www.fmcsa.dot.gov/regulations/cargo-securement/cargo-securement-rules#sthash.bMz8uSVQ.dpuf
