A Detroit 500 engine riddle, can it be solved
Discussion in 'Trucks [ Eighteen Wheelers ]' started by shogun, Sep 15, 2010.
  1. shogun
    shogun Road Train Member
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    My friend owns a 1999 Peterbilt with a series 60 Detroit 500. Last week, the truck kept cutting off, and he was in Salina, Ks and took it by a Detroit dealership. They told him that some wires were loose going to the ecm, tightened them up, and also some wires that go to the accelerator pedal needed repair. After the repair work, the truck started running fine again. They also got his cruise control back working, as it had been inoperable.
    Today, the truck was in mississippi and the turbo went out. This turbo is not even a year old, a Borg Warner aftermarket. According to the shop he bought it from, BW had issues with seals in certain models and the mechanic said the seals were bad in this one. So, they put the new turbo on, check the connections, and fire the truck up. The truck idles fine for about five or six minutes, so they bump up the idle with the cruise control. All of the sudden, the engine starts accelerating wide open, and it will not cut off.
    The driver cut the cruise off, and the truck continued to run wide open. He also turned the key off, but it still continued to run wide open. He and the mechanic got scared waiting for it to throw a rod, and they ran out of the shop. The shop has at least a 20 foot roof in it, and when the engine finally gave he said it shot water and oil everywhere, insomuch that water hit the ceiling in the shop.
    I assume that the motor is blown, probably a cracked head, etc. The question is what could the dealership have wired back incorrectly that would make the truck run wide open that even when shut off it kept on running wide open? The truck is governed, but supposedly it ran past the rpm governor. This is all secondhand information as I was not there. Any ideas? Thanks in advance.
    Shogun
  3. billandlori
    billandlori Medium Load Member
    357
    107
    Sep 5, 2010
    Stratford, Ontario, Canada
    Yikes!!!! Sounds scary.
    The old 2 stroke Detroits used to do that if they kicked back and would run backwards with no control of RPM. They had a big flap that would close off the air into the engine.
    Not sure what could have happened here, the key "should" kill it no matter what!!
    Bill
  4. thelastamericanhippy
    thelastamericanhippy Road Train Member
    1,038
    311
    Jul 10, 2010
    jacksonville, fl
    key turned off won't kill a runaway engine !!!!!
  5. 25(2)+2
    18,750
    45,491
    Sep 18, 2006
    the road less travelled
    Sounds like lube oil feeding the fire, the key will not shut it down because it's not the fuel system supplying fuel.
    I don't know what happened here to cause this, but something definitely went wrong.
  6. shogun
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    So far it has puzzled some mechanics. I am assuming it is something to do with the wiring, since a simple turbo swap would have no effect on the motor running wild. Its anyone's guess right now.
  7. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    I would bet good money that the new turbo was bad, probably at the intake side seal, sending oil into the intake, which the engine burned, causing a runaway situation.
    CallMeArty Thanks this.
  8. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    well you said the turbo went out, and they said the seals were bad, if they were oil seals, and the air to air was full of oil, and they did not clean all the piping and air2air then it was running on oil, not fuel. doesnt sound like anything wiring related, sounds more like old turbo related issue.
  9. CallMeArty
    CallMeArty HaMMeRED DoWN
    360
    293
    Apr 6, 2010
    TEXAS
    That mechanic should have known how to stop a "run away motor". If your wondering how its done... Starve it for air. Because of this mechanics lack of knowledge in his trade, he just cost a man some serious coin..... Whats a shame...
    TmGM Thanks this.
  10. shogun
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    Really Stranger? Could it be that the blown turbo also allowed oil into the intake side? The mechanic said that the seal on the slightly used turbo was bad.
  11. CallMeArty
    360
    293
    Apr 6, 2010
    TEXAS
    Exactly the scenario running through my mind. Starve it for air. As scared as I was when it happened, I've seen it done.
