A Few Flatbed Questions
Discussion in 'Experienced Truckers' Advice' started by Zephirus, May 30, 2009.
  1. Zephirus
    Zephirus Light Load Member
    51
    6
    Feb 27, 2009
    Hey everyone. Ive been driving a flatbed for a week now and I have some questions.
    First of all I love the work. Flatbedding is hard as hell. Strapping and tarping loads out in the hot sun is a real challenge but it gets you out of the truck and gets your heart pumping so its all good.
    I did have a few questions though for you more experienced ones out there.
    1. What is the easiest thing to use for edge protection? Right now I am using cornerboard (cardboard corners) because they came with the truck. I was thinking that something like 1 foot by 1 foot squares of carpet would be good to use. Light and they could bend to shapes better but im worried about them falling apart.
    2. How do you clean up after getting a load? Dust from straps, oil from chain cranks and rust dont really bother me but I hate to go to sleep smelling like sweat. I could wear coveralls to load but that wont help the sweat issue. Just wondering what other flatbedders do. Do yall shower everynight or give yourself a in-truck sponge bath or something? I mean I could change clothes but your body still stinks so it wouldnt really help. I may just have to take a shower everynight and pay for some since I doubt I use enough fuel to get free showers everynight. I like to keep the inside of the truck clean since I spend more time with my truck than I do at home but I am finding it difficult due to the sheer filth of straps, chains, and tarps.
    3. Chains or Straps? I prefer working with straps simply because they are lighter and easier to tighten down in my opinion. Plus you dont have to worry about rust and greasy cranks to tighten with. Can I simply use straps all the time or are there some things you must use chains for. I have hauled aluminum coils out of chicago before and we used chains for that. I am just wondering why people use chains instead of straps ever. You could use straps in the same way as chains for coils. Do the straps stretch or something? I just want to avoid chains as much as possible because they are heavy and nasty as hell.
    4. Any tips for tarping? I can do it just fine but it seems like it takes me longer than others. I dont know if they have a different technique or I am just being too #### picky. I normally fold my tarps to where I can put them at the front center of the load, and then pretty much unroll them all the way to the back. Once I have it unrolled, I can then unfold the sides and let the tarp fall down each side of the load. Tuck the excess under the load and then use the D rings to strap it down. Tarps are heavy as hell and I wish they made a light weight and durable tarp but anyway... and I cant afford those fancy tarping systems right now.
    Im sure I will have more questions down the road. I have hauled dry van and this is my frist time in flatbedding. Like I said, I love the work but I certainly need to learn some tips and tricks to speed things up and to stay a bit cleaner.
  3. Elvenhome21
    Elvenhome21 Heavy Load Member
    735
    240
    Nov 17, 2008
    Sheboygan, WI
    Im pretty sure 3 chains min are mandatory on coils, no straps unless used as extras after the 3 chains.
  4. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Steel on steel (chain) unless told otherwise by shipper. Straps on aluminum coils.(1 alum coil is about $200 grand) I use straps to belly wrap bar then use chains except on shiny bar no chains allowed. Chains are more stronger than straps. I use trip chains on front and back of pallets. You need to block coils shot gun and can criss- cross 2 chains and then horseshoe the rest. Couple straps across the top. Suicide coils can not criss-cross chains. You need to know how to build bulk heads and there is a lot to securing. You really need trained in this or you will kill yourself and possibly others around you.
  5. grizzly
    grizzly Medium Load Member
    599
    432
    Aug 27, 2008
    Layton, Ut
    I like cut up mud flaps for softeners under my straps. Go get an economy size package of baby wipes for cleaning up after tarping and such. They work well until you can find a shower. The carpet is great for protecting your tarps from sharp edges. As far as tarping goes it takes time to get fast. Get a system down that requires the least amount of moves. Like the other guys said, metal on metal. I prefer straps myself. Get yourself a strap roller, it will save time rolling up straps.
  6. Zephirus
    51
    6
    Feb 27, 2009
    notarps, I have just completed hauling 4 coils so I am not unexperienced, I was just wondering if straps were possible. I used chains on this past week. I just hate using chains cause they are nasty as hell and heavy to boot.
    I do see your point though, they are a lot stronger I am sure. Most of the time I use chains for loads that are very heavy that puts you almost at max weight. I use straps on lighter loads like scaffolding and such.
    Its just gonna take me a few weeks to get all the little tips and shortcuts learned. I am sure technique plays a big role in the time it takes to secure and tarp a load.
  7. lowbudget
    lowbudget Medium Load Member
    428
    110
    Apr 12, 2008
    Bismarck, ND
    you can't always say chains are stronger. for example, the chains my company provides have the same WLL as my straps (yeah they are cheap).
  8. notarps4me
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    I would not call 4 coils exp. I am not trying to be ugly here, but in another thread you was asking about a strap winder calling it a winch bar. Flatbedding is very dangerous. This is not like swinging the doors shut and rolling down the road. Flats will kill you or someone else in a heart beat. Most co's will require some sort of training and a reputable co's will require you to attend their load securement training even if you have been dragging boards forever.
    I have nothing against guys learning new gigs out here, but you really need load securement training before you kill you or me going down the road.
    Look at AL. They just passed a law requiring certification to haul coils in and threw that state because guys either didn't know how to secure or didn't care. Too many guys was losing coils.
    JennCTW Thanks this.
  9. notarps4me
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Steel will bite steel. Straps won't and straps cut if the load shifts.
  10. Allow Me.
    10,675
    12,234
    May 28, 2009
    Rancho Mirage, Ca.
    :biggrin_255:When I hauled flatbed, any processed steel was allowed to be tied down with straps. If it was raw, you needed chains. Coils were required to use chains. I preferred chains over straps on any steel. Whenever you load somewhere, ask questions from the other drivers that are loading.
    Get use to being dirty, it goes with the territory. You'll love getting cleaned up after a delivery, then getting a load two hours later, and getting dirty all over again.
    The tarping thing also goes with the territory. A word of advice; verify that it does indeed need to be tarped with the shipper. A lot of times, a broker will sell his services and throw in "free" tarping to the shipper, just to get the load. Then he dispatches the load as 'must tarp'. Good luck.
  11. TripleSix
    129,753
    Rule of thumb: Any coil loaded in coil racks, shotgun or suicide 24999 lbs or less need 4 chains. 25000 or more need 6 chains. Do not crisscross chains on a suicide coil. Shotgun coil needs straps across the top, never through the eye. If a coil is not on a skid, and it can roll, you have to put them in coil racks. DO NOT SIT THEM ON THE DECK OF THE TRAILER!!!
    If a coil comes lose, it will hit like a scude missile, blast through buildings, tear down walls and flatten trees and cars and other trucks.
