a few random questions
Discussion in 'Questions From New Drivers' started by DC843, Jul 22, 2015.
  1. DC843
    DC843 Medium Load Member
    672
    301
    Jul 4, 2015
    1. what do you do if you run into a low bridge on a street with heavy flowing traffic and other side of the road blocked off? would it be unheard of for dispatch directions to get you in this situation?
    2. do flatbeds and tankers catch less wind than vans?
    3. is your weekly 36 hour break your time to do what you want with it?
    4. is driving 11 hours every day with breaks throughout really as tough as its made out to be? it doesn't seem to me like it would be all that bad once you got used to it.
    5. if you drive in a team, can you split the driving time however you want to? is the truck expected to be in constant motion with 2 drivers?
    6. how long did it take you to start feeling "comfortable" driving?
    7. how long before you could back the trailer up with confidence?
    8. average miles a week for first year? with a home every 7 days schedule? I know it depends but average or your personal experience.
    9. is a flatbed or tanker any more difficult to drive than a regular van trailer?
    Thank you.
  3. XYZ123
    XYZ123 Bobtail Member
    26
    113
    Jul 21, 2012
    What is this 36 hour break you speak of? Maybe you are thinking of a 34 hour reset?
  4. DC843
    672
    301
    Jul 4, 2015
    yeah
  5. 2Girls_1Truck
    2Girls_1Truck Medium Load Member
    513
    640
    May 18, 2014
    Nova Scotia, Canada
    1. If you hit a low bridge, you will most likely have a police escort out of where you are. Use the time while you're waiting for them to pack your stuff since some companies are known to toss you out of the truck almost immediately.
    2. Tankers catch less wind and flatbeds would vary by the shape of their load.
    3. 34 hour reset (it's 36 hours for Canadian HOS) is your time. There is no rule preventing the company from bugging you though. You also don't "get" a 34 hour break each week. As long as you keep your hours below 70 in 8 days you can run forever with no days off.
    4. You are only required to take one 30 min break in the first 8 hours of your shift, and no, 11 hours is no big deal. Canadian HOS allows 13 consecutive with no breaks and we are no more unsafe.
    5. Teams are governed by the same HOS as other drivers. There is a somewhat confusing provision allowing splitting of sleeper birth for teams, but it isn't worth it IMO. The truck runs basically 24 hours a day.
    6. I felt comfortable pretty much right away. Ask lots of questions and don't hit anything.
    7. Backing up will be a work in progress and some days it's easy as pie and other days you couldn't hit the ocean from the beach. Turn the CB off if being made fun of bothers you.
    8. I didn't get a home every week job out of school and the miles totally sucked too. They played favourites with a certain few drivers and the rest of us "normies" were left to fight over the crap loads left over. I was doing maybe 2000 mi a week and making .30/mi.
    9. Yes and yes. The load securement/tarping makes flatbed more challenging than backing a van or reefer into a door and eating lunch. Also, I have a few friends who haul equipment on flattened and they have to load them on the trailer themselves. I have NO idea how to operate a huge excavator, a backhoe, a bulldozer, steam rollers and dozen of different farm tractors.
    The shifting fluid in a tanker makes stopping and cornering very different from a dry van. When you try to stop all of the liquid pushes up against the back of the truck, as ditto for sloshing side to side. Add in the hazmat and loading/unloading process, and it is a different world from OTR dry van.
    Hope this helps,
    taxihacker66 Thanks this.
  6. DC843
    672
    301
    Jul 4, 2015
    If I understand correctly the dispatch will send the route you take, what if they give you a route that has this problem on it? youll get fired?
  7. 2Girls_1Truck
    513
    640
    May 18, 2014
    Nova Scotia, Canada
    My dispatch does not provide us with directions to customers. Sometimes we have a phone number for the customer, but it's on us to figure out where we are going.
    G.Anthony Thanks this.
  8. 2Girls_1Truck
    513
    640
    May 18, 2014
    Nova Scotia, Canada
    If you hit a bridge, regardless of why you hit the bridge, you are most likely fired.
    The only possible exception would be if they are paving and the asphalt is raised higher so the height on the bridge is wrong. But you would have to be the first truck to go under it, since we are (basically) all the same height/width.
    Sometimes there are detours when accidents/construction close the highways. Some states are better than other for detour signs. I have never worked for a company that held our hands to the point that they would give us directions or route us. Trip planning has always been squarely my responsibility. That includes finding fuel stops and places to pull over for breaks, not running roads that are prohibited to trucks, etc.
  9. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Regardless of where or who your directions come from, YOU, the driver, are responsible for your routing. Check your route the best you can and always keep in mind that low clearance bridges will not always be listed in your truckers atlas, especially inside city limits, such as Chicago.
    Pintlehook Thanks this.
  10. DC843
    672
    301
    Jul 4, 2015
    ok I wrote the first question wrong, not HIT a bridge, but like have one up coming, stop before you hit, but be stuck on that street? how does this work if you cant turn around?
  11. 2Girls_1Truck
    513
    640
    May 18, 2014
    Nova Scotia, Canada
    Unless you were on a bridge, you would have find a driveway/parking lot and block the road to back into it and turn around. Bridges and truck routes are signed and marked...
    A bigger concern is missing turns and having to navigate a different exit or street to where you're headed. Google maps is extremely useful in these situations, also for scoping out truck entrances and parking lot orientation.
