A generic (sort of) Cummins Big Cam question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hogleg, Dec 5, 2016.
  1. Hogleg
    Hogleg Medium Load Member
    311
    258
    Nov 20, 2016
    Salem, Illinois
    The Pete 359 truck we bought had a rebuilt Cummins Big Cam engine and Eaton Fuller 13 speed transmission installed a few years ago. Sweet running engine. The engine came from an Autocar doner. Where do I look (exactly) to find the model numbers and version of this engine.
    On the driver side of the engine is a cable coming from the cab marked Throttle, and goes to a lever at the front upper part of the engine that seems to rotate a bar that goes inside the engine under the upper portion of the heads. What is this used for. When we pull the throttle handle the RPM decreases.
    John
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    That handle should make rpm increase its was used for running eng. in cold an hot weather to keep oil pressure up at idle it maybe hooked to wrong side of arm? look at L side of eng. for cpl # if you dont have the silver id plate pop riveted at the very ft. of left side of eng.
  4. 201
    201 Road Train Member
    12,621
    25,905
    Apr 16, 2014
    high plains colorado
  5. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    That was not available on big cam engines, that was a small cam only feature, it lifts the exhaust valves during cold cranking to allow the engine to gain cranking speed, once reached you would release and allow valves to close and usually start pretty quickly after that.
    wore out, Oxbow and 201 Thank this.
  6. Hogleg
    311
    258
    Nov 20, 2016
    Salem, Illinois
    I will take some pics. This could be a small cam. It does not say Big Cam on the side of the engine. It does have the large cam covers, though.
  7. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    It hopefully is a 400hp big cam that many Auto/car trucks came with back then?
  8. Hogleg
    311
    258
    Nov 20, 2016
    Salem, Illinois
    No such luck. I looked up the esn at cummins. A small cam made in 1973. A 290 originally. Who knows what they did on the rebuild.
    John
  9. Hulld
    Hulld Road Train Member
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    It's definitely a small cam and that is a compression release.
    I had a 1974 pete with a small cam 350 and it was rebuilt in to a 420 which was an industrial h.p. rating.
    I think the 290 could be built in to the same upgrade so the real h.p. rating on yours could be up in the air.
    As for the compression relief it's a great option for when weather gets to freezing and below.
    Pull that cable out and hit the starter and once she is wheeling over let go of the handle and she will fire right up.
  10. Oxbow
    Oxbow Road Train Member
    13,293
    137,690
    Nov 24, 2015
    It's been so long I can't remember.... wasn't a 290 naturally aspirated. And the turbo version a 350?
  11. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,141
    Mar 5, 2016
    White County, Arkansas
    I would remind some of you to make sure your fuel line is open (Handle on floor on left of your seat by door...)
    I don't recall a engine with compression release for cold weather. The ones I recall were Big Cam 4's usually. Otherwise it's either a 200's mack or a small Detriot.
