A good flatbed/step/heavy set up?
Discussion in 'Ask An Owner Operator' started by Battle Born, Apr 6, 2014.
  1. Battle Born
    Battle Born Heavy Load Member
    833
    344
    Feb 26, 2014
    Scandia, Mn
    Hey, I'm just looking for a good set up for a flatbed, step deck, heavy haul truck. Looking for mileage, power, and good rear ends and tranny. Any input is good input. Just trying to make it easier to single out trucks.
  3. BigCam9670
    BigCam9670 Medium Load Member
    417
    4,585
    Jun 12, 2012
    Hudson, NY
    Most engines will do the job just fine, I would recommend staying in the late 90's early 2000's era. Series 60 Detroit, N14, or 3406E/C15. 18 speed with either 3.70 or 3.90 gears. @1400 rpm you will be running ~62 with 3.90 and ~65 with 3.70. But with an 18 you will still have plenty of low gears to get you moving when heavy or if you are in soft ground when at a jobsite.
    Battle Born Thanks this.
  4. Battle Born
    833
    344
    Feb 26, 2014
    Scandia, Mn
    Yeah I really like the 18. I'm used to a 13, but the 18 will have a lot more to offer with that low end. I'm a huge fan of Cat engines, but I know that Detroit and Cummins for the most part are a little easier on fuel. I want to keep right around the lower 2000's if possible for now. I'm not a huge fan of DEF and all that.
  5. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,424
    Mar 23, 2012
    You can still get the series 60 Detroit without EGR and DPF (basically, no emissions control) from Western Star in the 4900.
    Was scopping out their reviews last night on youtube, guys seem to like it. Parts are easy to find and a lot of mechs are well trained on it.
    Edit- Sorry, just reread the brochure, it's only available on vocational vehicles.
  6. nightgunner
    nightgunner Road Train Member
    2,112
    2,800
    Jul 23, 2013
    Cedar Rapids, IA
    I am kinda partial to the 1997-2002 KW T800 with the 450 HP N14+ and 13 Speed. Running 24.5 tires, you should be able to avg 6.2-6.8 most days and have no problem pulling whatever you want. From the factory, the 3 Axle has a GVW of 85k. You can either add a Pusher (Hi $$$) or find one with a factory 4th. the N14 makes good power, has a great Jake, and costs less to rebuild that a Cat.
  7. Battle Born
    833
    344
    Feb 26, 2014
    Scandia, Mn
    I know my dad used to run an N14 for gravel and he loved it. I suppose I should have put light weight in there as well, but that's almost a toss up.
  8. nightgunner
    2,112
    2,800
    Jul 23, 2013
    Cedar Rapids, IA
    Depends, For most Flat/Step work if you can scale 46k lbs of freight, you will be just fine. If you are worried about weight, look at your trailer super close.
    When you say Heavy Haul, how heavy are you looking to go?
  9. Battle Born
    833
    344
    Feb 26, 2014
    Scandia, Mn
    I'd say somewhere about 105k plus? Im just thinking construction/farm equipment, military freight, stuff like that. Not the extreme stuff.
  10. nightgunner
    2,112
    2,800
    Jul 23, 2013
    Cedar Rapids, IA
    4 axle T800 500hp Cummins and 18 speed.
  11. nightgunner
    2,112
    2,800
    Jul 23, 2013
    Cedar Rapids, IA
    4 axle truck and 4 axle trailer gives you 150k lbs. Go with a 3 axle trailer with removeable stinger for more flexibility.
