A Little Lingo Help Please
Discussion in 'Questions From New Drivers' started by bwwhitt, Jun 28, 2013.
  1. bwwhitt
    bwwhitt Bobtail Member
    48
    13
    Mar 1, 2013
    Glendora, CA
    Fifth direct, third over ... what are they talking about with these gears? I am having a bit of difficulty locating a definition/explanation elsewhere so I figured it was time to turn to my favorite forums for some help. Sorry being noobish about this.
  3. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    On a 13 or 18 speed, direct and over, mean Direct and Overdrive positions in the auxiliary portion of the transmission as selected at the gear shift with the splitter button. These days they are usually referred to as L & H ie. Low and High in the past the shifter knob was labeled Dir. & O/D.
  4. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    On a 10 speed Overdrive, top gear is "over" and 9th gear would be direct.
    As in direct drive. Meaning the gear reduction is 1:1. So that the output shaft of the transmission is equal to the input shaft speed, ie the engine speed.
    In Overdrive, the output shaft is turning faster than the engine.
  5. SAMMY6969
    SAMMY6969 Medium Load Member
    371
    121
    Nov 12, 2011
    Lolo...MANNNNN..I HV ONLY BEEN DRIVING..OTR. 10 SPEED FOR 2 YRS...AND 9 SPEED DUMP TRUCK FOR 7 YRD ABOVE GROUND MINING CO...I NEVER NEW ANY OF THIS LINGO YOU GUYS ARE TALKING..NONE BESIDES DTOP IT IN THE HOLE....LOL...WOW...GUESS U DONT NEED TO KNOW LINGO IF YOU ASK THE RIGHT QUESTIONS...THANKS GUYS..
  6. TripleSix
    128,744
    5th direct would be the same as 9th gear. 3rd over would be 6th gear 18 speed transmission. You must be watching IceRoadTrucker Season 4.
  7. bwwhitt
    48
    13
    Mar 1, 2013
    Glendora, CA
    Actually season 6, when Austin helps with the 100 tonne push to Prudoe Bay.
  8. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    God help us I hated that season because of that kid. Last episode I caught was when he was talking to that driver about being tail heavy and spinning out.
    But as for direct and over they refer to 13 and 18spds. 3 over would be...uh...8th if I'm not mistaken that's counting low as 1st and 2nd gear. I don't use low unless I have too and it all gets pretty confusing I have respect for anybody that can actually count them off. And put numbers of the actual gears where they belong.
  9. TripleSix
    128,744
    I was thinking Season 4 when Lisa gets her first chance at push trucking with Jack and Carey. Season 4 was the last good season.
  10. Wymon
    Wymon Light Load Member
    249
    168
    Jan 13, 2013
    After watching IRT I'm almost embarrassed to admit I used to haul over the Dalton.
  11. bwwhitt
    48
    13
    Mar 1, 2013
    Glendora, CA
    Lessons learned so far from watching IRT season 6:
    - Just because you have your CDL doesn't mean you're the best (Austin, Darrel, and Porkchop)
    - No amount of driving time makes you better than other drivers (Darrel)
    - No amount of time with a company makes you better than other company drivers (*coughJackJesseecough*)
    - Quit whining, no one want to hear it (Austin)
    - A good attitude and a willingness to learn can take you a long way in the trucking industry.
