A.P.U?
Discussion in 'Ask An Owner Operator' started by TruckingSulzi_USA, Dec 30, 2007.
  1. TruckingSulzi_USA
    TruckingSulzi_USA Bobtail Member
    21
    Hey,
    how many of you have an APU installed to their Truck?
    If you have an APU, which one:
    Thermo King, Rigmaster, Blackrock,.....?
    Thanks,
    TruckingSulzi
  3. RoamingGnome
    RoamingGnome Medium Load Member
    454
    16
    Dec 1, 2007
    Pennsylavania
    my company doesn't have them but i wish they would. guess they like paying for the fuel i use while idling
  4. TruckingSulzi_USA
    21
    Yep, as far as i know Bison has them. But dont know who else.
    I am also wondering if the APU just charges the Batteries or directly runs the apps. in the cab??
  5. gearjammer-2000
    gearjammer-2000 <strong>Clutch User</strong>
    670
    205
    Dec 18, 2007
    columbus Ohio
    I have a blackrock with about 3000 hrs on it.
    It does have a generator on it but I only use it to run the block heater when the APU is on the rest of my 110 power is supplied by a 3500 watt inverter and the batteries are charged by the APU this way I have 110 power wether the APU is running or not .
    Heating with black rock is a hot water system off the coooling system of the Apu itself, it works fine unless it is really cold and then I hook up a 1500 watt cube heater which not only produces heat but works the APU a bit harder which causes it in turn to produce more heat.
    The cooling works good even in Laredo in the summer heat.
    I have had several other APU's in the past I got the Blackrock because of the ease of working on it, you can actually do a lot of the maintenance yourself , some of the other APU's on the market are so crammed together the its an all day job just to change the belts
  6. TruckingSulzi_USA
    21
  7. wally92
    wally92 Bobtail Member
    21
    washington , ill
    Walmart has them on all fleet trucks, charges batteries, keeps warm coolant through motor, on cold climate trucks we have a unit like a espar to keep the fuel from freezing when the trucks not running
  8. Steve & Lo
    Steve & Lo Medium Load Member
    358
    35
    May 22, 2007
    Tennessee
    We run a Tri-Pak by ThermoKing....and we love it....it comes with an 1800w inverter as part of the system....uses the truck engines cooling system...which keeps the block warm...and keeps the batteries charged. Can't imagine working without it....cool in the summer....warm in the winter....all for about a gallon a night....MAX!
  9. TruckingSulzi_USA
    21
    And how much was the Tri-Pak or the blackrock?
  10. Steve & Lo
    358
    35
    May 22, 2007
    Tennessee
    Thi Tri-Pak goes for right around $9K installed.....Which is an ALL DAY affair.
  11. gearjammer-2000
    670
    205
    Dec 18, 2007
    columbus Ohio
    the blackrock is also around 9k remember it has more cooling capacity than most others
