January 1, 2014 is less than three and a half months away....
So unless you have a rig that has an EPA '07 engine or newer....You won't be allowed to run in California...
I have read or heard estimates from the ATA....OOIDA....CARB....So on....That this will impact between 30-50% of all trucks currently running in and "To and Through" Cali....
That of course, is good for those who have the new rigs....The rates no doubt will increase as the Load to Truck ratio increases.....
But what happens to those trucks no longer running in or to Cali?....
Most likely the owners will continue to run outside....People have to continue to make a living right?
But......I think this is where the "Unintended Consequence Of CARB '14 Regs" will affect the industry significantly outside of California....And not with positive results...
I hate to say this but....With that glut of old rigs running the rest of the country....Rates outside California will fall greatly....
I won't speculate on how much the swoon will be or for how long....But this is Econ 101 stuff here.....
There will be more trucks chasing fewer loads....Rates will fall!!!
How many of you have thought of this possibility and, what are you doing to prepare yourselves for it?
A Possible Unintended Consequence Of CARB '14 Regs....
Discussion in 'Trucking Industry Regulations' started by Working Class Patriot, Sep 18, 2013.
Page 1 of 26
GeorgeDee and bullhaulerswife Thank this.
I have said that California can not tell what other state registered trucks can or can't do to enter the state as long they enter the state under the purpose of interstate commerce. It does not matter what the EPA has said is alright because the EPA can't allow one state or a few states to do this, it is regulating interstate commerce at this point.
It isn't their right to do so under their agreement with the US to enter the country as a state, they have to abide by the federal government's right to regulate interstate commerce, not make up rules and regulations that force another state's truck to get special equipment to drive on the roads that are federally funded, which is almost all of them in California.
So until the state of California starts actually fining people and taking their trucks, their laws are meaningless. But once that starts to happen, there is a serious legal issue that needs to be resolved and a bunch of lawsuits have to be filed against the state by individuals and by the OOIDA (among others) to force at least one court case that reaffirms the feds right to regulate interstate commerce and define what a state can or can't do. Because there is a bigger issue that has to do with this, the feds right to regulate a lot of things that were and still are state's rights issues, like health care insurance. If the feds refuse to stop CARB, then that means that all the other regulations built on the foundation of interstate commerce clause no longer are enforceable. -
First off...Cali can and will exercise it's 10th Amendment Rights...
Second....CARB regs aside....
We have 50 states employing almost 50 different regs on OS/OD loads and permits as it is...
What is legal height in CO (14' 6") is not necessarily legal in Cali (14')....
What is legal length in Cali (Up to 99') is not legal in AZ or UT....Both of those jurisdictions require a permit for loads over 9' off the tail.....
So how is that (Diverse OD/OS Regs) possible and Cali enforcing it's CARB regs not?GeorgeDee Thanks this. -
As far as enforcement?....
The CARB Nazis will be at the coops and Bug Stations....
And I would imagine when you renew your registration and Cab-card...Unless you have a compliant rig...Your issuing state will not accept "CA" marked off by you....GeorgeDee Thanks this. -
Because the OD stuff is less restrictive than the STAA minimums. If the states were to try and make rules to limit trucks to sizes smaller than the federal standard, there'd be issues. CARB's rules are more restrictive than the EPA rules, and should not be allowed to be enforced on out of state interstate carriers. But don't hold your breath waiting for the current administration to anything about it, as they just as soon see it nationwide. And they've shown a propensity to ignore the law when convenient to the desired outcome.
EPA's regs and rules are based off of CARB's regs and rules....
There was a CARB before there was an EPA IIRC...
Btw...For those who think Cali is wrong....
How is it that new rigs meet Cali's requirements...Since '08 (Some '07 rigs still had the '06 engines in them)....
Not only that...If Cali "Doesn't matter"....How is that many jurisdictions enforce anti-idling?
What we're seeing in Cali is the future for everywhere else....
Sorry...Don't shoot me....I'm just an observer....Emulsified Thanks this. -
It is true that the EPA tends to follow what Cali initiates, but that still doesn't allow Cali to enforce stiffer standards on interstate commerce. Imagine the outcry if no cars or motorcycles that meet 49 state emissions were allowed to cross into Cali.
SemperFiServices Thanks this. -
But this isn't a 10th amendment right, it is a federal issue and here's why;
The interstate commerce clause was put into the constitution for one purpose, to allow access to markets of one state by another.
Restrictions to the markets based on equipment happened a bunch of times in the 30's and because of the war, it gave the feds a new problem to solve fo it was decided in the 40's that harmonizing the regulations was needed so the states got together to create an agreement that harmonizes their laws and regulations so the feds didn't have to step in and do it for them. Most of them eventually deferred to the fed's regulations but that seemed to happen in 1955 or 56. Overall this is a federal issue because the problem with CARB is that it steps on the interstate commerce clause due to the fact they are saying in order for you to access our markets, you need a special piece of equipment that your state doesn't require you to have in your state to operate. in other words a truck from Michigan can't be told it has to have a specific piece of equipment to enter the state without Michigan having to require that piece of equipment on the truck that is registered in Michigan,.
Yes I understand but that's a different situation altogether, no one is saying to you hauling a OD load that you can't come into the state because you don't have a unique piece of equipment, they are saying you need to tell us what you are doing and we have to make sure you are abiding by our safety rules by purchasing a permit to haul that OD load. Remember that road designs are governed by the state but paid for by the feds and this is where the feds could say "oh well here is the new design for all the roads in the country, you got to make them like this from now on" and the states can't do much about it except complain but they gave the right to spec and build those roads for their needs.
Again this is a different issue, the state of California is telling us because we need special equipment we can't enter the state and hence have no access to the markets in that state to transport our goods.Last edited: Sep 18, 2013
DoneYourWay Thanks this. -
The issue of CARB over EPA was adjudicated in the courts years ago.
California won.
The main point being California had it's rules for exhaust and air requirements before the Feds did, so it was grandfathered.
California DOES have the right to enforce it's rules within it's borders and it is such a major market, it dictates what will happen elsewhere.
The auto companies quit building a separate engine for cars in 1969.
Trucks don't build 'California' versions.
Everything follows California's rules. As someone else said, 'As California goes, will go the rest of the country'.
The Feds have already proposed emission requirements stiffer than the current CARB requirements.
It will come to be.ShortBusKid and Working Class Patriot Thank this. -
Which one are you talking about, only one that I know of was about CARB regulations being stricter than the EPA and that was it.
While they have had the rules in place before the feds, it isn't grandfathered in. The EPA actually sets the minimal standard and they can have stricter rules.
Yes California has the right to enforce their regulations within their border ONLY for vehicle regisetered in California, they can't do it for vehicles registered outside the state.
As for the market dictating what happens elsewhere, not really dictating but rather just simplifying what companies are doing to cut costs.
Nope, that ended in the late 80s or 90's if I remember right with the advent of electronic fuel injection.
I don't know about trucks but cars were.
Yes this is true, they did but the problem is that:
1- we don't have a national program that forces retrofitting of emission controls like they do in Germany or other countries,
2 - that the states have to be involved with enforcing retrofitting if there is no national program,
3 - this has to all do with the fact that one state can't tell another one what to do.DoneYourWay Thanks this.
Page 1 of 26
