a pro at upshifting ,downshifting but I can't start on anything but 1st in 10spd
Discussion in 'Questions From New Drivers' started by mcmanly, Oct 16, 2014.
  1. mcmanly
    mcmanly Light Load Member
    175
    47
    Sep 22, 2012
    NE PA
    I never drove stick but instantly nailed up and downshift,my problem is starting .
    I let up my clutch half way let go off the brakes push fuel slightly well easing off clutch but I always end up nearly stalling. I ALSO HAVE PROBLEMS WOTH ROLL BACKS BUT AINCE WERE IN THE WOODS PRACTICING I DONT HAVE TO WORRY ABOUT IT
  3. ramblingman
    ramblingman Road Train Member
    1,152
    1,115
    Jan 12, 2014
    1.You should not be touching the throttle until the gear is fully engaged and the truck is rolling. You do that in Light duty vehicles with Syncronized Transmissions because they don't have the torque at idle to avoid stalling.
    2.To avoid rolling back you need to slowly let up the clutch with the brakes applied until you just barely start to feel the truck start to lift. Then you slowly let the brakes off while letting the truck up. You will need to do this very slowly on a steep grade if you have vehicles hugging your rear like they love to do.
    If you fail to avoid a roll back starting on a steep grade with vehicles kissing your ICC bumper you will see just how big of a worry it is.
    gpsman and Lepton1 Thank this.
  4. mcmanly
    175
    47
    Sep 22, 2012
    NE PA
    Wait!so no fuel till my foot is off the clutch?
    And I mean why bother working on stopping it from rolling when. I still gotta learn the basics
  5. DustyRoad
    DustyRoad Road Train Member
    1,540
    17,104
    Feb 23, 2011
    Gulf of Mexico
    What kind of equipment are you using?
  6. ramblingman
    1,152
    1,115
    Jan 12, 2014
    You can work on it later if need be, but you better have that down before you go out on the road and end up becoming another trucker MEME.
    blairandgretchen Thanks this.
  7. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    I'd kill you...lol not really
    Put it in fourth put your foot to the brake
    Don't let off the brake
    Pop the clutch
    Wait for the truck to rock side to side.
    Push clutch slightly back in
    Hold it there.
    Let off brake move it over to gas raise rpms say 300 while letting out the clutch .
    Sloooooowwwwwwlllllyyyyy
    But not too slow.
    You are just letting off the clutch too fast = stall
    Rolling back = you are pressing the clutch too far in. Let it rock. Press slightly in.
    See if that helps.
    Rocking the truck is a good safety check when someone's on your bumper at a light when first starting.
    Hope this helps...prob not. Be easier if I could just show you here xD
  8. ramblingman
    1,152
    1,115
    Jan 12, 2014
    I really hope your running an 18 speed if your starting loaded on a uphill grade in 4th gear or do you just have a personal vendetta against your transmission?
    Their is no need to apply throttle when starting until the gear is fully engaged. I've started on 6% grades with 79k gross without any vibrations or hesitations whatsoever..
    Lepton1 Thanks this.
  9. mcmanly
    175
    47
    Sep 22, 2012
    NE PA
    I thought you always start in fourth or fifth on a 10spd and pros on 6th?
    My teacher said do 4th or 5th but she is less of a teacher than anything
  10. CargoWahgo
    3,912
    3,945
    Jan 10, 2012
    I ain't got all day :p
    I'd drop it down to third on a big hill with over 35k in the box most likely.
    Anything under that is fine. Fifth to seventh.
    Go on about my day.
    If you can't go from 4th that's your problem.
  11. Dark_Majesty_06
    Dark_Majesty_06 Road Train Member
    1,072
    332
    Jun 15, 2009
    Poplar bluff, mo
    I've never started in 4th or 5th.. Even when I'm bobtail. I was taught to just start in first, no matter the situation. I usually like to take care of the transmission, so the starting in 1st all the time, is just personal preference but I can't see starting out in more than second, at highest.
