A question of rounding.......
Discussion in 'Trucking Industry Regulations' started by Powell-Peralta, Jun 28, 2010.
  1. Powell-Peralta
    Powell-Peralta Road Train Member
    1,585
    240
    Jul 17, 2007
    Basically, i want to know the regulation concerning rounding:
    1) For example, if i return to the terminal at 10:38am and want to conserve hours, can i round it back to 10:30am?
    a) How about 10:37am?
    b) Let's say i returned at 10:45 or 10:44am, could i round back 15mins to 10:30am under the pretense that not everyone's watch/clock is exactly the same so the FMCSA gives 15 mins "grace period?"
    Can you site the exact regulation(s) concerning #1, 1a, 1b? (i don't have my reg book in front of me presently.)
    2) In the next example, let's say i leave the yard at 9:45pm and return the next day at 11:45am (still within 14hrs). Later that day, if i leave at 9:37pm, but log as 9:45 using rounding logic is this ok?
    This is due to running a very tight schedule with specific delivery times.
    In other words, logwise i would be legal----if, in fact, rounding like that is permissible. But absolute time-wise, would i be in violation since it has been less than 10 hours (by a few mins) that i was off duty?
  3. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    I round everything off. Miles 10%, hours, states....:biggrin_25523:
  4. wsyrob
    wsyrob Trucker Forum STAFF Staff Member
    5,769
    5,463
    Sep 14, 2007
    Winston Salem
    If its 7 minutes past the 15 minute increment it goes backwards. At 8 minutes it goes forward. I keep my watch set 8 minutes fast and always round backward. That way its easy with no math to screw up.
    rookietrucker Thanks this.
  5. jtrnr1951
    jtrnr1951 Road Train Member
    I usually went with the 7/8 minute rule also.
    Looks like electronic logs will eventually solve this problem !!!!
    truckerdave1970 Thanks this.
  6. wsyrob
    5,769
    5,463
    Sep 14, 2007
    Winston Salem
    Yep and they will do away with the 8 minute P break to help out line 3.
  7. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    I just hope if they mandate electronic logs that they will allow 1/10's of an hour instead of quarters.
  8. jron619
    jron619 Medium Load Member
    404
    108
    Mar 26, 2007
    San Diego, CA
    I always thought of it a money. If something cost 52 cents then you must give 60 cents.
  9. Powder Joints
    7,657
    7,737
    Sep 25, 2007
    Rosamond, SoCal
    Personally, when behind the wheel I log to the closest, 7 back 8 forward.... At the end of the day (most of the time) I grab a clean log page and clean it up to ensure accuracy of course. I log between 49 and 56 mph depending on the state. But if there are substantial sized cities, like Los Angeles (Salt Lake, Las Vegas etc...) I don't count the miles across the city only city limit to city limit. If you ask a map program for the miles from Los Angeles to Las Vegas it will give you the closest city limit to the closest city limit, those are the miles I use.then subtract off 5 to 10% divide by 52 mph and thats the time I show, If there is extra time between time stamps looks like line 1 meals to balance the day. Protect your 70.
  10. tracyq144
    tracyq144 Heavy Load Member
    884
    546
    Feb 15, 2009
    MN
    I know you are being facetious, but elogs are the pits.
    The system I am currently driving under goes by the minute! Yep, don't start driving at 9 hrs 59 minutes on a 10 hour break, you WILL be in violation!
    I don't know if all elogs are the same, but ours suck.
    Add into that the lag in the Q-comm pipeline, and you better give yourself a 15 minute cushion before you start moving. And that cushion applies to all the other "duty status" changes.
    And then, of course, the satellite loses signal once or twice a day, and dumps you on line 4, even if you are in the sleeper.
    Yeah, this is a REAL good idea. Thank you, Big Government!!!
  11. Emulsified
    Emulsified Road Train Member
    3,663
    3,499
    May 6, 2010
    Dallas, TX
    I'm near sighted. Sometimes it's hard to read my watch. But it always reads the way I WANT it to. :biggrin_25515:
    Just know the answer they want you to know. I just had my second level 3 in as many weeks and both asked me that same question. My answer was: If 7 minutes or less, I round back. If 8 or more, I round forward. When in doubt I round to MY disadvantage.
    I came away with no citations at either inspection.
