A Question to Truckers About Dangerous Items to Transport
Discussion in 'Questions To Truckers From The General Public' started by crossroads_of_america, Mar 29, 2025.
  1. crossroads_of_america
    crossroads_of_america Bobtail Member
    5
    Mar 29, 2025
    Hello Truckers,
    A colleague told me that a business school professor claimed that the most dangerous item to transport with a semi-truck and tractor trailer is potato chips. The justification behind the claim is that the low weight of the product could make the trailer unstable and prone to causing the driver to lose control of the trailer. Could you shed some light on whether this claim has any basis? Are potato chips or other very light loads especially dangerous? How often do trucks transport empty trailers? (My thought would be that this is minimized since it could represent the loss of an opportunity for income.) Are there safeguards to stabilize light or empty trailers? If potato chips are not particularly dangerous, are there any other items which might present unexpected challenges to truckers?
    Thanks in advance for any thoughts. I am glad to be a part of this forum and to learn more about the profession.
    Flat Earth Trucker and Concorde Thank this.
  3. Concorde
    Concorde Road Train Member
    4,348
    15,458
    Jun 29, 2016
    West Melbourne Florida
    The only reason I can think of is (and I hauled a fair share of chips) for the person opinion is that a ftl of chips would be stacked to the ceiling. Heavier center of gravity. I think the last load I had was about 14,000 lbs.
    Is it the most dangerous, heck no. Probably tampons or dynamite could be the most dangerous :)
    Empy van or reefer trailers are dangerous in certain situations..wind, snow, or rain for example.
  4. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,327
    2,238
    Jan 7, 2023
    Your "professor" sounds like just another 4-wheeler pontificating about the industry while never having driven anything larger than his Volvo sedan.
    As far as the "most dangerous", I can think of at least 2 loads (outside of oddball O/S stuff..) that you can see driven on the highways regularly:
    The first is an un-baffled tanker, of which milk tankers comes to mind. These things are notorious for not only all the issues of "creeping center of gravity" on turns, but also for sever "slosh" when braking. As if that isn't bad enough, you see some of then running full-sized doubles on the NYS Thruway.
    The second is something which used to be common, but not so much today; swinging beef. Full sides of beef hanging from a hook on a track on the ceiling. Nasty handling on that....
    Lav-25, 88 Alpha, larry_minn and 8 others Thank this.
  5. Antinomian
    Antinomian Road Train Member
    2,078
    3,243
    Feb 17, 2013
    The only thing dangerous about potato chips is having the load rejected because all the bags burst when crossing over a mountain.
  6. crossroads_of_america
    5
    Mar 29, 2025
    Thanks Concorde for your response. I did not think about the height of the items being stacked. Is it not common for items to be stacked to the top of the trailer? I am guessing that it can be done for lightweight items, but for heavier items you might reach a weight limit that prevents them from reaching to high in the trailer. How many chips do you reckon made up the 14,000 lb load?
    Thanks again.
  7. crossroads_of_america
    5
    Mar 29, 2025
    Thanks Alex for the response. I never thought about sloshing liquids or items swinging around in the trailer. Could you explain what you mean by "oddball O/S stuff"? I don't know the term.
    Thanks.
  8. MACK E-6
    48,140
    219,733
    Think a ton of feathers vs a ton of bricks. One of those commodities will take up considerably more space on a truck.
    Oversize loads.
  9. Brandt
    Brandt Road Train Member
    4,422
    5,959
    Sep 17, 2012
    An odd one that dangerous to transport is Coca Cola or Pepsi. Not so much the cans/ bottles of soda. I hauled the liquid syrup they use to make the soda. It a hazardous material load that requires Corrosive placards on trailer.
    The potato chips are just like any other light weight load in my opinion. A semi truck is designed to haul 80,000 lbs. A little load is more easily to blow over in high winds and take longer to stop because you have more tires on the truck then needed for such a lightweight loads. If you hit the brakes hard all the tires don’t have enough weight pushing them on the ground. They have a tendency to slide on top of the pavement. You have 45,000 lbs in a trailer that weigh will push the tire on the pavement and they will grip. A truck has all the tires needed to handle and stop 80,000 lbs.
    It more difficult to stop and empty semi truck then a full loaded semi because when empty it doesn’t have enough weight keep all the tires needed gripping the pavement. So as a driver we should know this and keep more following distance and pay more attention to any high winds warning like you get out west in Wyoming.
  10. Ex-Trucker Alex
    1,327
    2,238
    Jan 7, 2023
    Oh, man, I first heard THAT "old wife's tale" about 40 years ago! That along with the Domino's Pizza driver who took too long to deliver his load of dough racks and hit the top of the Eisenhower tunnel because his load rose too high.....
    Just go away, please.
    Lav-25 and crossroads_of_america Thank this.
  11. crossroads_of_america
    5
    Mar 29, 2025
    Thanks Brandt. I did not consider that lightweight loads could be more difficult to stop due to less weight on the tires.
