A quick rundown on a sliding 5th wheel?
Discussion in 'Ask An Owner Operator' started by scoobertdoo, Jan 11, 2021.
  1. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    I have never had a sliding 5th wheel before.
    I thought it was just for moving weight to the front tires, but that doesn't make sense.
    Now I also have 24" side fairings.
    So do I slide the trailer forward for highways, and back to take sharp curves? Sorry if it sounds stupid, but I have never given it much thought since I have never had one.
    Thank you
  3. Cattleman84
    Cattleman84 Road Train Member
    9,947
    70,949
    Nov 1, 2017
    The Sticks, Idaho
    What kind of trailer do you pull? If it's just a van or reefer, and you haul standard frieght... Set it where you need to be inorder to axle out legal at max gross... Then NEVER move it.
    Rideandrepair and 77fib77 Thank this.
  4. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    Why does it have an air slide, if you don't move it?
    I'm going to pull a reefer
  5. bad-luck
    bad-luck Road Train Member
    3,319
    6,102
    Nov 16, 2013
    Baltimore, Maryland
    Its rather simple. If you want to add weight to your steers slide if forward. Put weight on your drives, move it backwards. Once you set it to where it needs to be you should not have to slide it. General rule of thumb is just forward of the center in the tandems
  6. snowwy
    snowwy Road Train Member
    20,569
    13,294
    Jul 6, 2009
    Different trailer setups.
    Put in a position for 12,500 on the steers. Full tanks and leave it if you're pulling the same trailer.
    Rideandrepair Thanks this.
  7. Dino soar
    Dino soar Road Train Member
    4,791
    26,882
    Dec 8, 2017
    Then you leave the fifth wheel where it is and you slide the tandems as you need to according to how you're loaded and the weight, etcetera.
  8. bad-luck
    3,319
    6,102
    Nov 16, 2013
    Baltimore, Maryland
    Correct. I was assuming the OP already had that part figured out.
  9. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    Lol yes. Only on my flatbed did the axles not slide.
    My biggest confusion was the air slide. Didn't make sense, since I have never moved it, why you would need to move it from inside the cab. Air 5th wheel release made more sense.
  10. Nitelyte
    Nitelyte Bobtail Member
    18
    11
    Sep 7, 2019
    North Carolina
    Get a beer load or close as you can to max. Make sure you 100% full of fuel too. Once your loaded scale and adjust your slider. Get close to 12k as possible and don't go over. You won't have to set it again really... if it's thats close your prbly running half fuel tanks at that point anyway. I personally use 1 notch forward of center and max my loads around 46k. Main rule is don't proceed overweight or under fueled. That 1000 lbs don't matter if your fueling every 300 miles. Shippers are responsible for letting you leave legal period. Go back and get things reworked if you have to. After a while you should know just by your pull and how much tire sag you have.. still scale bit you'll know your over. 1 notch is about 600 or so depending on the truck and load
  11. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    Do you think it's worth getting a anolog load gauge? It is on my short list of things to do right now. My pete doesn't have a suspension psi gauge.
    Rideandrepair and Nitelyte Thank this.
