about the 108 test
Discussion in 'Questions From New Drivers' started by soon2betrucking, Dec 2, 2007.
  1. soon2betrucking
    soon2betrucking Road Train Member
    1,658
    473
    Sep 28, 2007
    Philadelphia, Pa
    Hey folks, its been a few weeks since i posted, i have been way buisy working with the holiday running up on us, anyway, i have just completed my 10 weeks of classroom learning at school, on Monday I will start out on the Range, and for 2 weeks i will be practicing my 108, hands on, im just looking for any tips on good ways to memorize it, to make it easy, to make sure i hit at least 105 of them. well anything will work
    thanks to all.,
  3. ssbowles
    ssbowles Heavy Load Member
    708
    287
    Sep 27, 2007
    High Desert,CA
    I assume you're talking about the pre-trip inspection here. Check with the DMV and/or your school, one of them should have a diagram and a step-by-step order that they want you to follow. About the easiest way is to foolow along on the diagram over and over and over in the same pattern until it's branded into your memory.
  4. Scarecrow03
    Scarecrow03 Road Train Member
    3,411
    7,443
    Sep 27, 2006
    In Your Head
    The school I went to had a video tape of one of the instructors doing the pre-trip (like bowles, I'm assuming that's what you mean by 108 test) and we watched it over and over and over and over and over again.
    Ever watch a movie so many times that you know it by heart? That's what this video did for all of us at that school. Good ol' "Pre-Trip Bob". I tried searching for any kind of video like this on the web, but came up short. I'd recommend something like this, though.
    I aced the pre-trip test when I got my CDL. The examiner actually stopped me by the time we reached the back of the trailer. She said, "I can't give you a perfect score. My boss would never believe it, and actually neither would the state. We're going to have to stop with 105 out of 108." I couldn't believe it. Oh well, doesn't matter one bit today. It certainly hasn't hurt or helped me in my career.
  5. Bob Freeman
    Bob Freeman Bobtail Member
    8
    Dec 1, 2007
    Kingsport, Tennessee
    Start at the top and work down. Start at the drivers side and work back and when in the cab work from left to right. That way your less likley to forget something. And remember if your half way down the side of the vehicle and remember something you forgot mention it then you still get credit.
  6. LostBoy
    LostBoy Light Load Member
    161
    16
    davenport iowa
    the dot/mv in iowa has cards you can use to study from that lists the points. i read it aloud everynight for 2 weeksish while visuallising in my head where the part on the truck was. i could still rattle it all off, but am nowhere near that thorough on my pretrips.
  7. sweeze
    sweeze Light Load Member
    136
    8
    Aug 23, 2007
    Pacific Northwest
    I would suggest that you study as all the others have said, then when you have a ball park idea about what you need to say about what, start having people test you. At first i had other classmates test me. Then I snagged the classroom instructor as the grand finale. He ran me thru a mock test and showed me how to handle the lights (have the tester stay at the back and tell him what you are going to check when). Each time you do that it will stick in your head what you missed. I missed zero on the outside and two on the incab ( I was nervous and as a hen in a rooster house)
  8. soon2betrucking
    1,658
    473
    Sep 28, 2007
    Philadelphia, Pa
    Everyone! thanks, sorry its taken me a while to get back, with school and work, its getting harder to accsess the internet with the holdidays appraching fast, however, today at school we had a state examiner showing us what to do with the 108 inspection, it doesnt seem to bad, i mean there is A LOT to remember, and but next friday i have to recite this to the examiner, the good thing is there are 9 students doing the exact same thing, which is really good, cause for the past 10 weeks we have all worked very close with eachother and are a TEAM, so were all there for eachother, the bad thing is that there are 9 of us, i can see this going bad, " YOUR IN MY WAY! MOVE!, NO I WAS HERE FIRST! YOU HAVE TO WAIT!, NO YOU BEEN THERE LONG ENOUGH!!!" etc...
    well, i will keep everyone posted on how i do, thanks alot to everyone again
  9. russwhite86
    russwhite86 Bobtail Member
    28
    Mar 3, 2007
    Portage, MI
    When I was in school, our instructors had us repeat "Securely mounted, Not damaged and Not leaking" In Michigan its acceptable to use these terms and pretty much everything on the list fits into this...for the lights it was securely mounted, not damaged and working. Dont know if this will help, but it sure helped me.
  10. soon2betrucking
    1,658
    473
    Sep 28, 2007
    Philadelphia, Pa
    in Pa, its done like this
    3 L's, 2 W's
    1. Lean
    2. Leaks
    3 Lights
    1. Window
    2. Wipers
    Then we stand at the front of the truck and do the 3 L's and 2 W's and then,
    " Im going to check my AMBER marker lights are not Cracked, Bent, or Broken and are sucurley mounted to the vehicle"
    then we go to the right side of the truck and start at the exhaust pipe and we have to say " Im going to check my exauhst pipe and make sure its not Cracked Bent or Broken, and make im making sure there is no black sut, cause that can idicate there is a leak"
    for anything that is wrapped in rubber, its done like this
    "Im going to check my mirror mounts and make sure they are not Cracked Bent or Broken, properly sucured to the vehicle, im making sure my mirriors are clean, and im making sure that the rubber seal on the mirror is not Ripped, Torn, Frayed, or Dry-Rotted,"
    so if its metal its done that way and if its rubber its done that way.... its hard, cause we have to do it JUST LIKE THAT for everything......
  11. sjtrucker
    sjtrucker Light Load Member
    192
    66
    Nov 5, 2007
    Hayward WI
    In Wisconsin they have a memory aid that you are allowed to use on the test, it is in the book that you get from the DMV
