About to replace the turbo actuator on a VNL730...
Discussion in 'Volvo Forum' started by BigRobby, Feb 1, 2017.
  1. BigRobby
    BigRobby Bobtail Member
    Feb 1, 2017
    Hi there,
    I own a 2006 VNL730, and recently noticed that the turbocharger started to misbehave. So, it started kicking it at relatively low speeds, or sometimes even stopped at higher rpms... Anyways, I discovered that the problem is about the actuator unit, but the OE piece costs around 1K, which is quite costly... And I thought maybe I will get the aftermarket one... Though I never had any experience with aftermarket turbo parts, so was wondering maybe someone here tried something similar on their Volvos? Is it worth getting installed? Because I really like the price but am kinda concermed about the quality and the way it will operate on the truck....
    Any help's appreciated...
    D.Tibbitt Thanks this.
  3. PolishPrince
    PolishPrince Light Load Member
    296
    69
    Jan 11, 2017
    Chicago
    You get what you pay for. Turbo is a vital part of the engine. It will make or break your engine. Spend the money on you money maker and go buy an original
    D.Tibbitt and BigRobby Thank this.
  4. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    The turbo is a holset its the same one as on a. Cummins. You should be fine. The part dose not have to say Volvo
    D.Tibbitt, BigRobby and KB3MMX Thank this.
  5. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Actuator can be bought for 800 ... Don't pay 1000 that's a ripoff
    D.Tibbitt, Sharky88 and BigRobby Thank this.
  6. BigRobby
    Feb 1, 2017
    Well, I decided that I may give a try and will get an aftermarket actuator (https://www.carid.com/turbocharger-actuators/). At least will have my own experience on these guys... I appreciate your replies, folks. So now will hope that the new actuator will work fine on my Volvo...
  7. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    what kind of engine do u have cuz from the sound of it its either an isx or a d16 if it's isx you probably need to look at the actuator valve before actuator and those i know aftermarket and rebuilt have not worked to well. if it is a d16 make sure the turbo is not stuck inside.
  8. Sharky88
    715
    851
    Sep 25, 2013
    D13/16 or isx all use holset turbos. On my old isx I replaced the actuator with an aftermarket one with no problems but I guess that could always be a fluke and got lucky
    D.Tibbitt, KB3MMX and BigRobby Thank this.
  9. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Only $125 cheaper than OEM
    I hope it lasts
    AModelCat, D.Tibbitt and Sharky88 Thank this.
  10. zeljkorikverc
    zeljkorikverc Bobtail Member
    19
    Aug 18, 2018
    How did that actuator work for you?
