Abs and engine shutdown light
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rideandrepair, Nov 18, 2018.
  1. Rideandrepair
    17,430
    56,539
    Aug 8, 2015
    I recently fixed issue on 01 Freightliner abs rear harness abs sensors. All is good until 5 min ago while stopped for coffee red engine light and red shutdown and buzzer and abs light all came on for 5 seconds and all went off. Tried to pull codes and shows nothing. Any ideas?
  3. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    Sounds more like the cluster freaked out for a split second.
    Rideandrepair Thanks this.
  4. Rideandrepair
    17,430
    56,539
    Aug 8, 2015
    Maybe abs light going on is first sigh of bad ground? Then I lose ground or ? Completely. Truck shut down with no dash key on lights . Truck cranks all Other acc working not key on. Pulled fuse for ecm and shook wires around with key on. A minute later buzzer and dash lights came on started Truck and went back to TS. Trying to replicate problem all wires look good. Except 1 for power distribution module in fuse box. Gonna check if now
  5. Rideandrepair
    17,430
    56,539
    Aug 8, 2015
    Cleaned all grounds found very little corrosion on negative cables and 2 wires for ecm near battery box. Problem fixed. Thanks everyone
