ABS and TCS lights on VNL 760
Discussion in 'Questions From New Drivers' started by OvoBaJa, May 19, 2023.
  1. OvoBaJa
    OvoBaJa Bobtail Member
    Driving yesterday i had the ABS light and TCS light come on along with “Hill start assist is unavailable” the weird part is that it seems to turn off when i hit a bump but turns right back on afterwards and starts to flicker. The lights also turn off when i brake. Anybody have this problem before or might know whats going on? Seems that something might be loose or maybe some wiring issues because of the flickering? Wouldn’t the light be consistent?
  3. Moosetek13
    Moosetek13 Road Train Member
    14,714
    18,517
    Nov 1, 2010
    Burnsville, MN
    Maybe a loose connection or a glitch in the computer.
    When little things go wrong like that I will use the battery disconnect switch to sever the power, then reboot the system.
    Sometimes it helps.
  4. Todd727
    Todd727 Medium Load Member
    300
    583
    Jun 7, 2021
    Check the wheel sensors are all connected.
