ABS Combo Brake Valve Leaking Air
Discussion in 'Volvo Forum' started by tmslogistics, Oct 1, 2016.
  1. tmslogistics
    tmslogistics Light Load Member
    138
    15
    Mar 10, 2015
    Friend of mine has a 2009 Volvo 670. ABS Combo brake valve is leaking off air when the tractor brakes are released. He has already replaced the small valve...I believe it's the Quick Release Valve (QR1). This did not fix the problem.
    Any help would be greatly appreciated.
    Thanks,
    Toby
  3. AModelCat
    154,836
    Does it do it with the park brake set as well?
  4. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Check make sure none of the chambers are leaking internaly by punching the service side hose and see if the leak stops if it's not chamber then it it relay valve itself it is possible to buy separate and not whole assy about 100 usually unless he has fancy abs system
    AModelCat Thanks this.
  5. Mudman78
    Mudman78 Light Load Member
    106
    108
    May 23, 2016
    If it leaks out of the bottom exhaust all the time, the valve is no good. If it leaks out of the bottom exhaust only when the parking brake is released, then one of the brake chambers is bad.
    Kevins, wore out and AModelCat Thank this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,130
    Mar 5, 2016
    White County, Arkansas
    One possible source of leak is a failure to keep sludge out of the system, it gets into the chamber seal between the spring side and the dry side erodes the seal and boom leak. You will literally watch your air drain out of there and wonder if your springs are going to apply and finish your stopping.
  7. tmslogistics
    138
    15
    Mar 10, 2015
    NorthernMechanic....only leaks off when the breaks are released!
  8. tmslogistics
    138
    15
    Mar 10, 2015
    how does he check to see if his brake chambers are bad?
  9. AModelCat
    154,836
    Like nasriza said. Pinch off the lines at the service port of each brake chamber, one at a time with the brakes released. When it stops leaking out of the valve, you've found the leaking brake chamber. Just chock the wheels first!
    Reason for edit: I can't spell lol
    x1Heavy and wore out Thank this.
  10. wore out
    wore out Numbered Classic
    15,407
    185,953
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Pinch of the emergency side line at the chambers one at a time if leak quits when one is pinched it's bad
    x1Heavy Thanks this.
