Abs light on now
Discussion in 'Freightliner Forum' started by missjhawk, Nov 5, 2017.
  1. missjhawk
    missjhawk Medium Load Member
    571
    324
    Jul 24, 2013
    nutbush
    I finally replaced bearings in my truck but i bought the entire hub it was cheaper on parts and labor the parts come from freightlinner but now my abs light is on they clear hard code but light never goes off got to take it back next weekend caz i am under a load. But my truck is not shaking no more they wanted my old hubs but i took them later on I'm gonna put new bearings in old hubs for spare parts i assume that's what the shop was gone do when they were shocked i asked for my parts but why is my abs on it wasn't on b4 I replaced hubs
  3. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    Perhaps one of the abs sensors are not making proper contact to the tone ring/ and or is dirty with some kind of muck that happened while exchanging hubs... or perhaps the sensor feed to the tone ring became unhooked during the hub switch or was not locked together properly with a zip tie if taken apart
    Have you checked all the sensor leads first to make sure their all plugged together?
    missjhawk Thanks this.
  4. Hulld
    Hulld Road Train Member
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    Does the abs light come on immediately after clearing the codes with out moving the truck?
    Or do the wheels of the truck have to turn before the abs light resets?
  5. missjhawk
    571
    324
    Jul 24, 2013
    nutbush
    When i took truck back they found our its my passenger side they jacked that side up got a can of brake fluid sprayed the inside while turning wheel they checked wires above slack adjuster hooked computer back up erased code but when turn truck back on light is still on they wanted 2 try more stuff but my time was short my truck was 2 be completed on sat
  6. missjhawk
    571
    324
    Jul 24, 2013
    nutbush
    The light never go off even when they clear or out with computer
  7. Hulld
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    If the code doesn't clear with out even moving the truck there is an open circuit to one of the abs sensors.
    Unplug the abs sensors and look for damaged or bent pins in the connectors.
  8. xsetra
    xsetra Road Train Member
    5,133
    7,035
    Aug 21, 2011
    What hub did you change.
    Steer axle abs sensor can easily be checked on my truck. I just push the sensor back into position against the tone ring using a pry bar.
    The sensors on drive axle are harder to get at. But there is an access hole directly behind sensor to push it forward with a stiff wire,,, clothes hanger or long nose punch.
    If you have an open circuit, you probably have a damaged wire. I would first check the wire that the hub was replaced.
    Plug in a new sensor into each position unplugging old. One at a time. Checking if abs light goes out. This will show you which position is bad.
    I think the computer should tell you when running the diagnostics. I mean the laptop the shop plugs in to your truck.
    Good luck
    missjhawk and HopeOverMope Thank this.
  9. OneTwentyOne
    OneTwentyOne Light Load Member
    76
    22
    May 19, 2016
    Hi, from experience, had a seal replaced in steer. The speed sensor was not appropriately spaced with the tone ring. Had it adjusted and the light went off after I drove off. It remained on for about two miles, but then just went off. Just from my experience, also if you have fluids in the area of the sensor it could be causing some issue. Good luck.
