Abs light
Discussion in 'International Forum' started by Showtimetrucking, Aug 14, 2011.
  1. Showtimetrucking
    Showtimetrucking Bobtail Member
    10
    Fort worth, texas
    I have a 2004 intnl 9400i, and my abs light is on and it's a automatic transmission, since this light has come on my transmission will only ####f if I do it manually for each gear, and SM is displayed in the gear indicator.
    Can someone please help
  3. Heavyd
    Heavyd Road Train Member
    7,752
    6,186
    Feb 4, 2009
    Part of the ABS system that the tranny needs to work is the traction control. With the ABS faulting the traction control is now offline and the trans is just defaulting to manual mode. You will need to get the ABS looked at.
    JohnC123 and 123456 Thank this.
  4. jab8283
    jab8283 Bobtail Member
    38
    16
    Jan 16, 2010
    Indiana, U.S.
    The three biggest faults I've found here are blown fuse, dirty wheel sensors or damaged and sometimes unplugged wire harness. First check your ABS fuse in fuse panel behind glovebox door and if fuse is good, then with your engine off, key in ON position, next to ignition switch is flip switch for ABS. Flip it and read the codes that pop up on the ABS idiot light (same way you read fault codes for your engine). The fault code will tell you what has failed including which wheel end is affected if it's a bad or dirty wheel sensor. Sometimes a blown fuse is your only failure. Whether it's a fuse or a problem with wiring harness or wheel end sensor, sometimes idiot light doesn't automatically go out. If that happens after repair, drive your truck around the block and the ABS will automatically detect no problems and go out on it's own. Usually it's as simple as that. Check that fuse first, then check the fault codes and proceed from there. The fault code will give you the clues to isolate and repair if issue is real.
    JohnC123 Thanks this.
  5. 6Dad
    6Dad Bobtail Member
    I flipped the abs blink code. It blinks so how do I understand what the blinks mean.
  6. JohnC123
    JohnC123 Light Load Member
    135
    66
    Jan 25, 2018
    Count the number of flashes, it should repeat this three times, you can find these references and fault descriptions on-line for all makes.
