abs light
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ljmenez1, Jan 23, 2015.
  1. ljmenez1
    ljmenez1 Light Load Member
    73
    4
    Dec 30, 2014
    los angeles ca
    hello,
    I have a 2008 kw t2000 and my abs light turn on, reading on some post here I was able to find a test switch under the dashboard above the throttle. I opened the key and and held the switch to test mode. the abs light flashes for about 3 times and stops and flashes again 2 or 3 times but does not read any codes it just stays on (abs light) can any one tell me if im does this wrong or how can I get the codes so I can see what is wrong.
    Thanks in advance,,,
  3. Heavyd
    Heavyd Road Train Member
    7,816
    6,270
    Feb 4, 2009
    It is flashing the code sequence. The number of flashes represent the digits of the codes. The pause in between the flash sequences means it is about to flash the number of the next digit. Most abs systems are 2 digit codes. So if it flashes 4 times, then a pause, then flashes 5 times your code would be 45. Try it again and see what you have.
    ljmenez1 Thanks this.
  4. ljmenez1
    73
    4
    Dec 30, 2014
    los angeles ca
    Thanks for your input I will try it and let you know.
    Thanks again
  5. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    Just to finish your question, "abs lights", are a PITA!
  6. ljmenez1
    73
    4
    Dec 30, 2014
    los angeles ca
    Well if i did it right it should read 23.
  7. ljmenez1
    73
    4
    Dec 30, 2014
    los angeles ca
    its either 231 or 23 does any one know the correct code? and if so what is the problem?
    Thanks
  8. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Flash code 23 is a open or shorted wheel speed sensor on the left steer axle if it's a Bendix ABS system. For Wabco, 23 is for the right rear drive modulator valve. So you need to identify the system.
    If you don't know and there's no indication on the switch, since your ECU is hidden under your dash, the easiest way is to identify it is to look at the drive ABS relay valve/modulator package. It's usually mounted on the cross-member by the 5th wheel. On a Wabco system, the modulators bolt to the relay valve with 2 bolts each. On a Bendix system, the modulators screw into the relay valve (pipe thread). Or call a dealer with your VIN and they can tell you what you have.
    In either case, a wiring issue is the most likely cause. For the steer, it's often a rubbed wire. They zip tie them with the brake hose, so check that out really good. Follow the wire to the plug and you can ohm out the sensor, if it's open or shorted, there's you'r issue, you need a sensor, which is easy on a steer axle.
    If it's the rear modulator, it can get a little more involved checking the wiring. Let us know what kind of system you have. Both types of ABS have the troubleshooting manuals online.
    When you find the issue, keep in mind that the ABS light might no go out until it senses wheel speed. You often have to drive 5-7 mph so the ECU can complete it's drive away test to clear the lamp.
    ljmenez1 and rank Thank this.
  9. ljmenez1
    73
    4
    Dec 30, 2014
    los angeles ca
    Thanks i guess my morning will be bussy, can i drive the truck like that?
  10. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    You can drive it, but it is a DOT violation. The ABS light just means that the ABS has an issue and may not be fully working. It does not affect the normal service brakes.
  11. rinkusaini
    rinkusaini Bobtail Member
    8
    Oct 20, 2017
    i have an 2014 Frieghtliner Cascadia and the abs lights don't come on when running the self diagnostics when i switch on the ignition. fuses and bulbs are good. i can hear the valves clicking when iswitch on the ignition. any ideas?
